help rs 232
gladkih
help rs 232
PostPosted: Tue Feb 17, 2009 11:36 am     Reply with quote
i have problem
program
#include <18F452.h>
#device *=16
#device ICD=TRUE
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES PROTECT                  //Code protected from reads
#FUSES DEBUG                    //Debug mode for use with ICD
#include <stdio.h>
//#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
INT16 B;
#byte leds=0x09
#bit led_1=leds.0
#bit led_2=leds.1
#bit led_3=leds.2
#byte RS_485=0x07
#bit DE=RS_485.2
#bit HF=RS_485.5
#DEFINE ON 1;
#DEFINE OFF 0;
#INT_RDA
VOID PRIEM()
   b=fgetc();
   led_1=1;
      clear_interrupt(INT_RDA);
char c[]="cfgjgh";
set_tris_E(0x00);
set_tris_C(0x9B);
HF=Off;
DE=On;
led_1=0;
led_2=1;
led_3=1;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(INT_RDA);
//,INVERT,FORCE_SW
   WHILE(1)
   DELAY_MS(100);
   putchar('1'); DELAY_MS(100);
      putchar('2');   DELAY_MS(100);
         putc('3');   DELAY_MS(100);
            putc('4');   DELAY_MS(100);
               putc(5);   DELAY_MS(100);
                  putc(6);   DELAY_MS(100);
                     putc(7);   DELAY_MS(100);
                        putc(8);   DELAY_MS(100);
                        putc(0);   DELAY_MS(100);
                        putc(0xFE);   DELAY_MS(100);
      DELAY_MS(100);
      putchar(c[1]);
        DELAY_MS(100);
and data on terminal
C3 FC;HEX;
C4 FC;HEX;
C7 FC;HEX;
C8 FC;HEX;
0B FC;HEX;
0C FC;HEX;
0F FC;HEX;
30 FC;HEX;
00;HEX;
FC;HEX;
8C FF;HEX;
I am VERY bad speak english(I am from ukraine). Pplease help me with program.
PostPosted: Tue Feb 17, 2009 12:52 pm     Reply with quote
#device *=16
This line is not needed. The 18F compiler always uses 16-bit pointers.
#byte leds=0x09
#bit led_1=leds.0
#bit led_2=leds.1
#bit led_3=leds.2
#byte RS_485=0x07
#bit DE=RS_485.2
#bit HF=RS_485.5
The addresses used for 'leds' and 'RS_485' are wrong. Thoses addresses
are for the 16F PICs (such as 16F877). To find the correct addresses
for Port E and Port C in the 18F452, look in the 18F452 data sheet, in
the following section:
TABLE 4-1: SPECIAL FUNCTION REGISTER MAP
#INT_RDA
VOID PRIEM()
b=fgetc();
led_1=1;
The line in bold is not necessary. The CCS compiler automatically puts
in code at the end of the interrupt routine to clear the RDA interrupt.
PostPosted: Tue Feb 17, 2009 12:59 pm     Reply with quote
PCM programmer wrote:
#device *=16
#byte leds=0x09
#bit led_1=leds.0
#bit led_2=leds.1
#bit led_3=leds.2
#byte RS_485=0x07
#bit DE=RS_485.2
#bit HF=RS_485.5
#INT_RDA
VOID PRIEM()
b=fgetc();
led_1=1;
SORRY I HAVE PIC16F877A.I DONT UNERSTEND WHY DATA IN TERMINAL
NOT == DATA IN PIC
PostPosted: Tue Feb 17, 2009 1:02 pm     Reply with quote
Then don't post stuff like this:
#include <18F452.h>
How can I believe your code is accurate ?
PostPosted: Tue Feb 17, 2009 1:21 pm     Reply with quote
#include <18F452.h>
#include <16F877A.h>
#device *=16
#device ICD=TRUE
#device adc=8
#include <stdio.h>
INT16 B;
#byte leds=0x09
#bit led_1=leds.0
#bit led_2=leds.1
#bit led_3=leds.2
#byte RS_485=0x07
#bit DE=RS_485.2
#bit HF=RS_485.5
#DEFINE ON 1;
#DEFINE OFF 0;
#INT_RDA
VOID PRIEM()
   b=fgetc();
   led_1=1;
char c[]="cfgjgh";
set_tris_E(0x00);
set_tris_C(0x9B);
HF=Off;
DE=On;
led_1=0;
led_2=1;
led_3=1;
   setup_adc(ADC_OFF);
   WHILE(1)
   DELAY_MS(100);
      DELAY_MS(100);
      putchar(c[1]);
        DELAY_MS(100);
PostPosted: Tue Feb 17, 2009 4:49 pm     Reply with quote
Your program is too complicated. Make a very simple program to test
the RS-485. Let the compiler set the TRIS. It will do it automatically
if you use CCS functions. Example:
#include <16F877.h>
#define DE  PIN_C2
#define HF  PIN_C5
output_low(HF);
output_high(DE);
printf("Hello World\n\r");
Also, CCS has a feature in the #use rs232() statement, where you can
specify the Enable pin for the RS-485 driver chip. Example:
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, ENABLE=PIN_C2)
I don't know what the "HF" pin is doing in your program, so I left out the
code for it.
PostPosted: Wed Feb 18, 2009 12:40 am     Reply with quote
#include <16F877.h>
#define DE  PIN_C2
#define HF  PIN_C5
output_low(HF);
output_high(DE);
#include <16F877.h>
code for it.
I HAVE MAX3089. I DO ALWAYS IN AND FULL DUPLEX.
