18f4550 Analog Vref
boily
18f4550 Analog Vref
PostPosted: Mon Feb 16, 2009 6:58 pm     Reply with quote
I started a project on a 16f877a and I was using a 3.3V Vref for the analog port.
I could set A0 to A2 as analog input and A3 as a Vref !
How can I right that for the 18f4550 ?
Can I still do it ?
PostPosted: Mon Feb 16, 2009 7:06 pm     Reply with quote
Look in the ADC section of the 18F4550.h file. It tells how to do it.
It lists the constants to be used with setup_adc_ports().
c:\Program Files\picc\Devices\18F4550.h
boily
PostPosted: Tue Feb 17, 2009 7:55 am     Reply with quote
yeah I look into that but can't find how to set the Vref :
//////// Standard Header file for the PIC18F4550
Header File removed.
Reason: Forum Rule #10
10. Don't post the CCS example code or drivers, or ask for such code
and drivers. Please do NOT copy this code into the forums.
This includes header files for devices (example 18f452.h).
-- Forum Moderator
boily
PostPosted: Tue Feb 17, 2009 8:44 am     Reply with quote
Answer: setup_adc_ports(AN0|VSS_VREF);
