rx and tx dont tied down
julian
PostPosted: Mon Feb 16, 2009 1:36 pm     Reply with quote
Im using eusart of a 18f4520, when my process finishes i need to tied down the RX and TX pins, so I use output_low(PIN_C6); and output_low(PIN_C7); but it doesnt work, what can i do?Crying or Very sad
dyeatman
PostPosted: Mon Feb 16, 2009 1:56 pm     Reply with quote
I would expect you will first have to disable the EUSART before you "take over" the pins to control them...
setup_uart(false);
This "disconnects" the EUSART so you can control the I/O pins.
Of course you will have to turn it back on when you get ready to use it again.
SherpaDoug
PostPosted: Mon Feb 16, 2009 2:41 pm     Reply with quote
Note that low is not the usual idle state for serial pins. If the UART is still active when you pull the serial pin low it will see that as a Start bit and clock in a garbage character. You are doing something unusual, so it may take a bit more typing than the usual.
julian
PostPosted: Mon Feb 16, 2009 4:36 pm     Reply with quote
Thank you dyeatman and SherpaDoug .
Problem solved. I use set_uart(FALSE) like dyeatman say and now my program works well
Very Happy
julian
PostPosted: Tue Feb 17, 2009 6:30 pm     Reply with quote
Using setup_uart(FALSE); bring another problem, now my mcu doesnt wake up, this is the code I use at the end of my program
setup_uart(FALSE);
output_c(0x00);
output_d(0x00);
delay_ms(2000);
output_low(RELAY);
ext_int_edge(2, H_TO_L);
enable_interrupts(INT_EXT2);
clear_interrupt(INT_EXT2);
I tried this
//setup_uart(FALSE);
#asm ASIS
BCF    0x0FAB.7
BCF    0x0FAB.4
#endasm
//delay_ms(100);
 output_c(0x00);
 output_d(0x00);
//delay_ms(2000);
   output_low(RELAY);
//   delay_ms(500);
   sleep();
yesterday without setup_uart(FALSE); mcu wake up
Thanks in advance
