temopic
Driver / help required for atmel AT45DB161D |
Posted: Sat Feb 14, 2009 8:48 pm |
Could some one help regarding a driver for a AT45DB161D, I am using a pic18f4520 and the PCWHD 4.065 but waiting for my latest version licence for upgrade, already bought |
Posted: Sat Feb 14, 2009 9:24 pm |
A search with google turned up some Dataflash info that may help you get started:
Additionally, the below page has links to Dataflash driver C code that should give you a framework for how it's done and looks like it will translate fairly easily.
http://blog.blockos.org/?tag=arduino
It appears the CCS command spi_xfer() would be the equivalent to thier command spi_transfer()
drdelphi
Posted: Sun Feb 15, 2009 4:19 am |
try this :
Code: | #define FLASH_SELECT PIN_... // output
#define FLASH_CLOCK PIN_... // output
#define FLASH_DI PIN_... // output
#define FLASH_DO PIN_... // input
void init_ext_flash(void);
void ext_flash_startContinuousRead(int pageAddress);
void ext_flash_sendData(int data, int size);
void ext_flash_sendBytes(char* data, int size);
void ext_flash_getBytes(char* data, int size);
void ext_flash_readPage(int pageAddress, int pageIndex, char* data, int size);
void ext_flash_writePageThroughBuffer(int pageAddress, char* data, int size);
int ext_flash_getByte(void);
void ext_flash_waitUntilReady(void);
void init_ext_flash(void) {
output_low(FLASH_CLOCK);
output_high(FLASH_SELECT);
void ext_flash_startContinuousRead(int pageAddress) {
ext_flash_waitUntilReady();
output_low(FLASH_SELECT);
ext_flash_sendData(0xE8, 8);
ext_flash_sendData(pageAddress, 14);
ext_flash_sendData(0, 10);
ext_flash_sendData(0, 16);
int ext_flash_getByte(void) {
int flashData = 0;
output_high(FLASH_CLOCK); flashData += input(FLASH_DO); output_low(FLASH_CLOCK);
output_high(FLASH_CLOCK); flashData *= 2; flashData += input(FLASH_DO); output_low(FLASH_CLOCK);
return(flashData);
void ext_flash_getBytes(char* data, int size) {
int i, j;
for(i = 0; i < size; i++) {
for(j = 0; j < 8; j++) {
shift_left(data + i, 1, input(FLASH_DO));
void ext_flash_readPage(int pageAddress, int pageIndex, char* data, int size) {
ext_flash_sendData(0xD2, 8);
ext_flash_sendData(pageIndex, 10);
ext_flash_getBytes(data, size);
void ext_flash_writePageThroughBuffer(int pageAddress, char* data, int size) {
int i;
ext_flash_sendData(0x82, 8);
for (i = 0; i < size; i++)
ext_flash_sendData((int)data[i], 8);
void ext_flash_sendData(int data, int size) {
do {
size--;
output_bit(FLASH_DI, (data >> size) & 1);
} while(size > 0);
void ext_flash_sendBytes(char* data, int size) {
int i;
void ext_flash_waitUntilReady(void) {
int flashData;
output_bit(FLASH_DI, 1); output_high(FLASH_CLOCK); output_low(FLASH_CLOCK);
output_bit(FLASH_DI, 0); output_high(FLASH_CLOCK); output_low(FLASH_CLOCK);
for(;;) {
flashData = 0;
if (flashData == 172) break;
