IF statement not works
nicotec
PostPosted: Fri Feb 13, 2009 9:16 am     Reply with quote
Dear user, I need of your help since IF statement in my code doesn't work; could someone help me how to write in correct form the IF statement?
Thanks in advance and regards
#include <input.c>
char temp[6];
#int_rda
void Serial_isr()
   char string[6], term[3], *ptr;
   char *valore;
   char *comando;
   printf("Enter string: ");
   get_string(temp, sizeof(temp));
   printf("\n\rReceived: %s \n\r", temp);
   strcpy(string,temp);
   strcpy(term,",");
   ptr = strtok(string, term);
   comando=ptr;
   while(ptr!=0) {
      //puts(ptr);
      valore=ptr;
      ptr = strtok(0, term);
   if(comando!="55")
   printf("\n\rComando= %s \n\r", comando);
   printf("\n\rValore= %s \n\r", valore);
PostPosted: Fri Feb 13, 2009 10:53 am     Reply with quote
The reason the 'if' doesn't work, is that you cannot compare strings with the '!=' test. This _only_ applies for numeric values.
However, consider doing this all a completely different way. You are really 'abusing' the point of the interrupt. The idea of a serial ISR, should be to get just the _one_ character that is waiting in the hardware buffer. In your ISR, you are getting multiple characters, and outputting even more. Since potentially you are in the ISR, for 12 character times, before you even read a character, the hardware buffer (just two characters), can easily be overloaded, resulting in loss of characters (at the least), and hanging the UART (at the worst).
Do a search here about this. Unless you really know what you are doing, you should keep interrupt handlers short. If you want a 'input routine' triggered by the arrival of the first character, use something like the ex_sisr code, but add a flag, so that as soon as the interrupt is triggered, your main code calls the actual input routine. Avoid doing complex tasks like this in the ISR.
nicotec
PostPosted: Fri Feb 13, 2009 12:42 pm     Reply with quote
above pic24 has 4 character buffer, so there are no risk to lost since I send only 5 char not so quickly; could you hel me to solve IF statement problem?
thanks
nicotec
PostPosted: Fri Feb 13, 2009 1:17 pm     Reply with quote
Please provide me a solution on if statement; i tried a lot of combination like =='55' ="55" but since i'm new user i need of your help.
thanks
PostPosted: Fri Feb 13, 2009 1:46 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=36705&highlight=strcmp
http://www.ccsinfo.com/forum/viewtopic.php?t=34302&highlight=strcmp
nicotec
PostPosted: Fri Feb 13, 2009 2:11 pm     Reply with quote
Thanks, so I can change my code as follows?
#include <input.c>
char temp[6];
#int_rda
void Serial_isr()
   char *valore;
   char *comando;
   char *pan_chk;
   strcpy(pan_chk,"55");
   strcpy(term,",");
   comando=ptr;
   while(ptr!=0) {
      //puts(ptr);
      valore=ptr;
   if (strcmp(comando,pan_chk)!=1)
What do You think?
Regards
PostPosted: Fri Feb 13, 2009 2:30 pm     Reply with quote
There is no guarantee that strcmp() will return a value of 1.
If the strings are equal, it returns a value of 0.
If they are not equal, it returns a positive or negative number.
You need to get a book on C, or read an online tutorial on C.
In other words, we don't want to teach how to use every ordinary
C function such as strcmp(). You need to get a book about it.
nicotec
PostPosted: Fri Feb 13, 2009 2:33 pm     Reply with quote
Sorry to disturb, I have already ordered a book and waiting it to receive.
Regards
