Int16 handled as int8 in this ex.
PostPosted: Wed Feb 11, 2009 6:12 am     Reply with quote
This is _only_ a small test program.
Why is "t" printed as a 8bit?
Whats wrong here, is it a compiler bug?
void x()
char str[3]={'5','4','5'};
int16 t;
t = (((str[0]-48)*100) + ((str[1]-48)*10) + (str[2]-48));
printf("%Lu\n",t);
andrewg
PostPosted: Wed Feb 11, 2009 6:40 am     Reply with quote
The printf is fine. The problem is that all the numbers and variables in the line:
are 8 bit (except for the t, which doesn't count for the purposes of evaluating the expression), so the all the math and final result are 8 bit too. At least part of the expression needs to be changed to use 16 bit math.
My recommendation, since you're multiplying, would be to use the _mul() function (see your manual/online help) to achieve that end:
t = _mul(str[0]-48,100) + ((str[1]-48)*10) + (str[2]-48));
You get both optimal multiply code, plus the 16 bit result you need.
Andrew
Wayne_
PostPosted: Wed Feb 11, 2009 6:44 am     Reply with quote
Because str[0] is 8 bit, str[1] is 8bit and str[2] is 8bits.
It is doing 8 bit maths throughout the equation and placing the result in your 16 bit var.
5 * 100 = 500 = 244 (8bit) +
4 * 10 = 40 +
5 = 5
244 + 40 + 5 = 289= 33 (8 bit)
Are you getting the result of 33 ?
My wrap around conversion may be flawed but that is most likely what is happening.
Try putting (int16) before the str values e.g.
((int16)str[0] - 48) * 100 etc
PostPosted: Wed Feb 11, 2009 7:20 am     Reply with quote
Hi
Wayne you are right, adding a cast to int16 solve the problem, but is that normal?
A simple add like this will only work with cast to int16?
int16 val;
int8 t=5;
.................... val = (t-48)*100;
0CF4:  MOVLW  30
0CF6:  SUBWF  t,W
0CF8:  MULLW  64
0CFA:  MOVF   PRODL,W
0CFC:  CLRF   val+1 <- Here it clear!
0CFE:  MOVWF  val
.................... val = (int16)(t-48)*100;
0D00:  MOVLW  30
0D02:  SUBWF  t,W
0D04:  CLRF   @@x85
0D06:  MOVWF  @@x84
0D08:  MOVFF  @@85,??65535+1
0D0C:  MOVWF  ??65535
0D0E:  CLRF   @MUL1616.P1+1
0D10:  MOVLW  64
0D12:  MOVWF  @MUL1616.P1
0D14:  RCALL  0CD2
0D16:  MOVFF  02,val+1
0D1A:  MOVFF  01,val
0D1E:  GOTO   0E6C (RETURN)
Wayne_
PostPosted: Wed Feb 11, 2009 7:32 am     Reply with quote
Quite normal.
