I2C Problem in PIC24
deczerdenz
PostPosted: Mon Feb 09, 2009 3:06 am     Reply with quote
I have problem in I2C communication using PIC24FJ64GA002 as my slave.
I used LED to verify if my code is OK. To validate my code, I add "output_high(PIN_B7);" And I observed that the LED will not be high after the line "if (state >= 0x80)".
1. Why is it my code will not output high after the "if (state >= 0x80)"?
2. Is my i2c_isr_state correct?
Slave Code:
#include <24FJ64GA002.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_B13, rcv=PIN_B12)
#define  I2C_Address  0x60
#INT_SI2C
void SI2C_interupt()
   //There is no point in using poll. If the ISR is called, a byte _is_ waiting
   indata = 0;
   indata = i2c_read();
   state = i2c_isr_state();
     if (state <0x80)
    { //Here read from master is required
      switch (state)
      case 0:
         Caldata[0] = indata; //address
      case 1:
         Caldata[1] = indata; //constant
      case 2:
         Caldata[2] = indata; //constant
      case 3:
         Caldata[3] = indata; //counter
      case 4:
         Caldata[4] = indata; //command
      case 5:
         Caldata[5] = indata; //checksum
      default: //extend states here, if more than two writes are needed
         //Here master has tried to write more than two bytes
         //Just ignore the data
       I2C1STAT_COV = 0; //0x208.6 - Receive Overflow Flag in I2CxRSR
       I2C1_IWCOL = 0; // 0x208.7 - Write Collision Detect-> 1=Collision 06102008RA
       I2C1_TBF = 0; //0x208.0 - Transmit Full Status Bit-> 1=full 06102008RA
       I2C1_RBF = 0; //0x208.1 - Receive Full Status Bit -> 1=Full 06102008RA
 if (state >= 0x80)
      data = 0xff;
      switch (state)
      case 0x80:
        i2c_write(0);
        checksum = 0;
      case 0x81:
         data = 0x30;
         transmit[state] = data;
         i2c_write(transmit[state]);
      case 0x82:
         data = 0x35;
      case 0x83:
         data = 0;
      case 0x84:
         data = 0;
      case 0x85:
         data = speed_settingA & 0x0f;
         if (input(sense) == 0)
           data |= 0x20;
         if (input(sense1) == 0)
           data |= 0x40;
         if (input(error) == 1)
           data |= 0x80;
         if (input(error) || input(error1) == 1)
           data |= 0x80;
      case 0x86:
      case 0xB9:
         transmit[state] = checksum;
      default:
        checksum += transmit[state];
Can anyone help me?
Thank you very much.
