Jockl Guest
Problems with #use i2c |
Posted: Fri Feb 06, 2009 1:26 am |
Can anyone help me with this error? The whole program works without this line(bold), but with this line I get this error
*** Error 44 "C:\IPP UMTS\C-Code\Main.c" Line 9(5,52): Internal Error - Contact CCS PPUSE
Program:
Quote: |
#include <16F877.h>
#include "Main.h"
//#FUSES INTRC_IO,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,NOLVP,NOCPD,NOWRT,DEBUG
#use delay(clock=8000000)
#use i2c (SLAVE,sda=PIN_C4,scl=PIN_C3,address=0xa0)
//#use rs232 (BAUD=19200,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
#use STANDARD_IO (A)
#use STANDARD_IO (B)
#use STANDARD_IO (C)
#use STANDARD_IO (D)
#use STANDARD_IO (E)
Posted: Fri Feb 06, 2009 2:42 am |
Try a very simple program like this and see if you still get the problem:
Code: | #include <16F877.H>
#use delay(clock = 4000000)
Also,
1. Re-install the compiler.
2. Post your compiler version. It's given at the top of the .LST file,
which will be in your project directory after a successful compilation.
It's a number in this format: x.xxx |
Jockl Guest
Posted: Fri Feb 06, 2009 3:04 am |
I re-installed the compiler (4.038) and now it works fine.
Thanks and best regards,
Jockl |
