Passing a const 2D array to a function?
PICoHolic
PostPosted: Thu Feb 05, 2009 6:08 am     Reply with quote
Is there a trick to pass a const 2D array as parameter to a function.
for ex:
const byte img1[6][84] = {0, 1, 2, 3, 4, ...};
const byte img2[6][84] = {8, 6, 3, 3, 4, ...};
etc ...
I have several tables and i need to pass a given one to a function.
i have tried:
void my_func(byte **img)
and
void my_func(byte img[6][84])
Thanks...
PostPosted: Thu Feb 05, 2009 7:02 pm     Reply with quote
I tried for a while and I can't make it work.
You might have to use if-else or switch-case statements to
select which array to access (rather than passing a pointer).
See the TEXT array in glcd.c for an example.
PostPosted: Fri Feb 06, 2009 3:46 am     Reply with quote
Remember that in CCS, the most efficient way to store a 'const' array, doesn't support pointers.
Simplest solution using this method of storage, is to make the array 'global', and just pass the line number to the function, as an integer. Remember also, that inside the function, you will need to access the array using array accesses (table[a][b]), rather than using pointers, and for operations using pointers, you will need to copy the row to RAM using strcpy, before using these.
