SprintF question ...
boily
PostPosted: Tue Feb 03, 2009 1:45 pm     Reply with quote
I'm trying to do a sprintf and I'm only getting constent 0.00000 reading from my analog imput....
What am I doing wrong ??
Is there another way to print decimals on my LCD ?
Thanks Smile
int8 x;
float g;
char msg   [10];
char espace [21];
x = read_adc();
g = (x-110)*(1/36);
sprintf(msg, "%f", g);
strcpy(espace, "                   ");
strcat(msg, espace);
ecrire_chaine(msg);
PostPosted: Tue Feb 03, 2009 2:22 pm     Reply with quote
Make and post a full test program (meaning, with #include, #fuses,
etc). You can test this problem with two lines of code in main().
Get rid of all the escrite stuff and run the test program in MPLAB simulator
and display the output with printf in the Output window. You can test the
whole thing. You can experiment with it. You can try different width and
precision values for the "%f". You can play around with it until you make
it work.
Sample of short test program with link to instructions on using UART1
in MPLAB with the MPSIM simulator to test a program's output:
http://www.ccsinfo.com/forum/viewtopic.php?t=36961&start=1
How to display floats on an LCD:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
Charlie U
PostPosted: Tue Feb 03, 2009 3:22 pm     Reply with quote
Remember, when doing arithematic in C that you must think like the compiler/processor. Look at the line where you assign a calculated value to g. First, x is an int8 so it can only have values from 0 to 255. What happens if you subtract 110 from a value that is less than 110? Also since you are doing integer math, what is 1/36? The answer to the second question should answer your question.
To achieve the results that you are hoping for, you will need to learn about "casting". Do a search on this.
Wayne_
PostPosted: Wed Feb 04, 2009 3:15 am     Reply with quote
ptr=strcat (s1, s2)
Concatenate s2 onto s1
int8 x;
float g;
char msg   [10];
char espace [21];
x = read_adc();
g = (x-110)*(1/36);
ecrire_chaine(msg);
s1 (msg) is 10 chars that is 9 chars + the null termination char '0'
s2 espace is 21 chars, 19 space + null = 20 (OK)
s1 + s2 = 29 chars. buffer overrun. Your msg array is not big enough!
Also, are you sure sprintf(msg, "%f", g); will produce a string of less than 10 chars ? you may be better fixing the size:-
sprintf(msg, "%6.2f", g); // "nnnnnn.nn\0" 10 chars
boily
PostPosted: Wed Feb 04, 2009 7:55 am     Reply with quote
thanks guys Smile
boily
PostPosted: Wed Feb 04, 2009 9:59 am     Reply with quote
how do I print only 3 decimals ??
I did the %3.2F thing but its not working ...
PostPosted: Wed Feb 04, 2009 10:56 am     Reply with quote
You'd want something like %6.3f The last digit is the 'number of decimals', but the first is the 'total field width'. Your number can have a digit in front of the decimal, and at times a - sign, and there is the decimal itself. Hence the total field needs to be 3 more than the number of decimals.
boily
PostPosted: Wed Feb 04, 2009 5:14 pm     Reply with quote
thanks, its working fine now Very Happy
