RAMBO29
How to access SD21 Servo controller from CCS Compiler? |
Posted: Mon Jul 18, 2005 12:07 am |
I am using P18F452 MCU and SD21 servo controller with MPLAB 7.2 and
CCS compiler. But I am unable to get the servos working.
This is the code I am using.
#include <18F452.h>
#use i2c(MASTER,SDA=PIN_C4,SCL=PIN_C3,address=0xc2)
#define SD21 0xC2
#define servo1 0
#define Servo2 3
#define Servo3 6
#define Servo4 9
#define Servo5 12
#define Servo6 15
#define Servo7 18
#define Servo8 21
#define Servo9 24
#define Servo10 27
#define Servo11 30
#define Servo12 33
#define Servo13 36
#define Servo14 39
#define Servo15 42
#define Servo16 45
#define Servo17 48
#define Servo18 51
void main ()
unsigned char tmp[3];
i2c_start();
tmp[0]=0;
tmp[1]=0x34;
tmp[2]=0x08;
i2c_start(); //I2C Start
i2c_write(SD21);
i2c_write(servo1); //Memory location
i2c_write(tmp); //Data
i2c_stop(); //I2C Stop
i2c_start();
tmp[0]=0;
tmp[1]=0x7C;
tmp[2]=0x05;
i2c_write(SD21); //Chip Address
i2c_write(servo2); //Memory location
Thanks in advance. |
Posted: Mon Jul 18, 2005 1:34 pm |
Look at this page, which has sample Visual Basic code for the SD21:
http://www.robot-electronics.co.uk/files/EH2_SD21_BX24.txt
Scroll down near the bottom of that page, until you get to
the Sub I2cByteWrite function. Anything that talks
to the SD21 uses that routine. So that's the main routine
that you want to translate. Once you've done that, all the
rest of the code is easy, because it mostly calls that routine.
Here's a sample program where I've translated the I2cByteWrite
and BackRightRev functions to CCS. I've also translated some
constants and a variable. If you compare this code to their code,
you see how to translate the rest of it.
Code: | #include <16F877.H>
#use delay(clock = 4000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#define SD21 0xC2 // SD21 I2C Address
#define RFPbck 119
#define LMPbck 111
#define RRPbck 117
int8 Speed;
void I2cByteWrite(int8 I2cAddr, int8 I2cReg, int8 I2cData)
i2c_start();
i2c_write(I2cAddr); // send device address
i2c_write(I2cReg); // send register address
i2c_write(I2cData); // send the data
i2c_stop();
Void BackRightRev(void)
I2cByteWrite(SD21, RFPbck, Speed);
I2cByteWrite(SD21, LMPbck, Speed);
I2cByteWrite(SD21, RRPbck, Speed);
Speed = 10;
BackRightRev();
while(1); // Prevent PIC from going to sleep
Posted: Wed Dec 24, 2008 3:12 am |
Did you solved your trouble?
If you did it, could you tell how to do in the forum?
I'm a complete noob with the same problem that you.
Thanks! |
Posted: Tue Feb 03, 2009 3:50 pm |
Can anyone expain how the SD21 gets its instructions. Im not familar with I2C and I cant seem to find a simple program to domonstrate this.
The main problem is the datasheet for the SD21 is clear on how to write to the registers. Here is my code so far.
Code: | #include <18F4520.h>
#device ICD=TRUE
#device adc=8
#FUSES NOWDT, WDT128, INTRC_IO, NOPROTECT, BROWNOUT, BORV20, NOPUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, IESO, FCMEN, PBADEN, NOWRTC, NOWRTB, NOEBTR, NOEBTRB, NOCPB, NOLPT1OSC, MCLR, XINST
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
#use delay(clock=40000000)
i2c_start(); //start tansmission
i2c_write(0xC2); //write to board address
i2c_write(??); // Im not sure on rest
i2c_write(??);
i2c_write(??);
i2c_stop();
Posted: Tue Feb 03, 2009 4:24 pm |
Quote: | #FUSES NOWDT, WDT128, INTRC_IO, NOPROTECT, BROWNOUT, BORV20, NOPUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, IESO, FCMEN, PBADEN, NOWRTC, NOWRTB, NOEBTR, NOEBTRB, NOCPB, NOLPT1OSC, MCLR, XINST
#use delay(clock=20000000) | 20MHz is a wrong setting. INTRC_IO selects the internal oscillator with a clock frequency in the range 31kHz to 8MHz. Check the datasheet for the possible frequencies.
The XINST fuse enables the eXtended INSTruction set. This feature is not supported by the CCS compiler and is known to create problems. Change to NOXINST instead.
You have selected NODEBUG but also device ICD=TRUE, these two instructions are the opposite of each other. I'm not sure what the compiler will make of this, but it might be different from what you want it to be. Solve the conflict.
Code: | #use delay(clock=40000000) | You really like changing the clock frequency, don't you? If 20MHz is too fast, then for sure 40MHz isn't going to work either. Only put one '#use delay' line at the start of your program (unless you know exactly what you are doing and have good reasons for a second clock setup).
Right now it looks like you have no clue as to what you are doing. My suggestion to you would be to first create a simple program blinking a led at a 1 second interval. This is the most simple program but important because it proves your hardware is working correctly. And from there start expanding the program in small increments.
Anonymous wrote: | Can anyone expain how the SD21 gets its instructions. Im not familar with I2C and I cant seem to find a simple program to domonstrate this. | You have found this thread with some great pointers provided by PCM Programmer, what more do you need???
I never used the SD21 servo, but looking at the provided example programs there is all the info I would need. |
Posted: Thu Feb 05, 2009 8:28 am |
Yes you're correct. I need to stop relying on the wizard to set things correctly for me. But my actual question is how to communicate the I2c data to servo controller. The data sheet doesn't really tell you how.
#include "math.h"
#device ICD=TRUE
#device adc=8
#FUSES NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP, INTRC_IO
setup_wdt(WDT_OFF);
setup_vref(FALSE);
i2c_start();
i2c_write(SD21); // send device address
i2c_write(0x00); // send register address
i2c_write(0x00); // send the data
i2c_write(0x01); // send register address
i2c_write(0x4c); // send the data
i2c_write(0x02); // send register address
i2c_write(0x4); // send the data
i2c_stop();
Above is the main code for my test program. I have the servo that I'm testing moving but it doesn't seem be correct. when I send 1100 to lowbyte/highbyte the servo should move left not right. Then when I go to the opposite 1800 it still moves to the right. I don't know if the way for sending the data is correct. |
Posted: Thu Feb 05, 2009 8:31 am |
Sry accidently deleted #define SD21 0xC2 in my code posting. But it is in the program. |
Posted: Sat Feb 07, 2009 1:11 pm |
After a little playing around I fiqured out the answer to my question thanks for your help. |
