nicotec
all in a string |
Posted: Tue Feb 03, 2009 9:38 am |
Code: | #use rs232(UART1,baud=9600,parity=N,bits=8,stop=1)
#define BUFFER_SIZE 10
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_RDA
void RDA_isr()
int t;
output_high(PIN_B7);
buffer[next_in]=getc();
t=next_in;
if(next_in==next_out)
next_in=t; // Buffer full !!
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
return(c);
long an_1;
long an_2;
long an_3;
char mystring;
setup_spi(SPI_SS_DISABLED);
setup_spi2(SPI_SS_DISABLED);
setup_wdt(WDT_ON);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
enable_interrupts(INT_RDA);
enable_interrupts(intr_global);
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,10000 );
setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
setup_compare(2,COMPARE_PWM | COMPARE_TIMER2 );
setup_adc_ports( sAN9 | sAN10 | sAN11 );
setup_adc(ADC_CLOCK_INTERNAL );
set_pwm_duty(1,1000); // 2ms on status
set_pwm_duty(2,1000); // 2ms on status
output_low(PIN_B8); //common pin for led
output_low(PIN_B6); //led off
output_low(PIN_B7); //led off
do
set_adc_channel( 9 );
an_1 = read_adc();
set_adc_channel( 10 );
an_2 = read_adc();
set_adc_channel( 11 );
an_3 = read_adc();
output_high(PIN_B6);
printf("%Lu%c%Lu%c%Lu%c%c",an_1,10,an_2,10,an_3,10,13);
while(bkbhit)
output_low(PIN_B7);
putc(bgetc());
} while(true);
Hi, I need to put all result characters from [bgetc()] in one string only[mystring] which will be analyzed.
Thanks in advance
Regards |
nicotec
Posted: Wed Feb 04, 2009 8:42 am |
The referenced code:
Code: | my_get_string(mystring, 3); |
works to wait a string, but I need to continue other job and only on RDA interrupt taking the string received.
Any suggestion?
Thanks and regards. |
Wayne_
Posted: Wed Feb 04, 2009 10:07 am |
If this is all you are doing with recieved data the you almost have it with your current code!
There are some unanswered questions though.
How much data ? How big does your string need to be ?
void RDA_isr()
int t;
t=next_in;
Change this routine so that when you recieve the end char or x amount of data you process that buffer and then start writing to the buffer from the start again.
One issues with this is if you recieve data while you are processing the current data then it will be lost. You can fix this with 2 buffers. If your processing time takes longer than the gap between blocks of data then you have a big problem because you would need infinate memory to store it all as you cannot process it quick enough.
Single buffer routine
#define MAX_BUFFER 100
char buffer[MAX_BUFFER];
int8 index = 0;
int1 process_flag = false;
#int_RDA
void RDA_isr()
char c;
c=getc();
if (!process_flag)
buffer[index++] = c; // store data
if (index >= MAX_BUFFER) // Got all the data
process_flag = true; // ignore data untill this buffer has been processed
index = 0;
You can try and work out the double buffer option. |
nicotec
Posted: Wed Feb 04, 2009 11:42 am |
First of all thanks for your help and I try to explain what I doing. I send to pic a code like "55,61" or "4,1" ended with LFCR
In my code I send to PC (my VBcode) a string for other work... now I need to use interrupt to detect a received string like as above, so I whish to obtain my string like "55,61" |
nicotec
Posted: Wed Feb 04, 2009 1:44 pm |
I'll try (I hope tomorrow) this code; can anyone help me to confirm/suggest/correct anythings about the following code after explanation on what I want to do above?
Thanks in advance and regards.
p.s.: I'm interested to obtain in string "input_str" the string sent to pic like as "55,61" ended with LFCR
Code: | #include <24FJ16GA002.h>
#include <string.h>
#FUSES NOJTAG //JTAG disabled
#FUSES ICS3 //ICD communication channel 3
#FUSES IOL1WAY //Allows only one reconfiguration of peripheral pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES FRC //Internal Fast RC Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is general purpose output
#FUSES NOPR //Primary oscillaotr disabled
#FUSES I2C1SELD
#use delay(clock=8000000)
#pin_select OC1=PIN_B0 //OUTPUT OF PWM PIN 4
#pin_select OC2=PIN_B1 //OUTPUT OF PWM PIN 5
#pin_select U1TX=PIN_B10 //RS-232 TX PIN 21
#pin_select U1RX=PIN_B11 //RS-232 RX PIN 22
#BYTE U1RXREG = 0x226
#define BUFFER_SIZE 32
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
int t;
t=next_in;
output_low(PIN_B7);
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
return(c);
//clearing=U1RXREG;
void my_get_string(char* s, unsigned int8 max) {
unsigned int8 len;
char c;
--max;
len=0;
do {
//c=getc(); // Commented out.
c = bgetc(); // Call bgetc() instead of getc()
s[len++]=c;
} while(c!=13);
s[len]=0;
#define STRING_SIZE 40
long an_1;
long an_2;
long an_3;
char input_str[STRING_SIZE];
setup_wdt(WDT_ON);
do
an_1 = read_adc();
an_2 = read_adc();
an_3 = read_adc();
my_get_string(input_str, STRING_SIZE-1);
printf("\n\rYou typed: %s \n\r\n\r", input_str);
output_low(PIN_B7);
} while(true);
nicotec
Posted: Thu Feb 05, 2009 7:09 am |
Below code (extracted from above) is in loop waiting character/string and I wish to not remain in loop but exit if no interrupt RDA verify since it's not necessary to be in a loop because I need to do other job for my pic24fj16ga002.
Can someone help me, please?
Code: | void my_get_string(char* s, unsigned int8 max) {
unsigned int8 len;
char c;
--max;
len=0;
do {
if(c==8) { // Backspace
if(len>0) {
len--;
putc(c);
putc(' ');
putc(c);
} else if ((c>=' ')&&(c<='~'))
if(len<=max) {
s[len++]=c;
putc(c);
} while(c!=13);
s[len]=0;
