Comunication problem PC - PIC18F4550
PostPosted: Sun Feb 01, 2009 5:42 pm     Reply with quote
Hello, I have problems with this code:
#include <18f4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL3,CPUDIV1,VREGEN,NOPBADEN  //Ordenes para el programador
#use delay(clock=12000000)  //fosc= 12 Mhz
#use standard_io(b)
char boton=' ';
#int_rda
void serial_isr() {
  boton=0x00;
  if(kbhit()){
    boton=getc();
     if(boton=='1'){                      //this does not work
   output_toggle(PIN_B0);
     if(boton=='2'){                     //this does not work
     output_toggle(PIN_B1);
     if(boton=='3'){                      //this does not work
     output_toggle(PIN_B2);
     if(boton=='4'){                       //this does not work
     output_toggle(PIN_b3);
     if(boton=='5'){                        //this does not work
     output_toggle(pin_b4);
     if(boton=='6'){                        //this does not work
     output_toggle(pin_b5);
     if(boton=='7'){                         //this does not work
     output_toggle(pin_b6);
     output_toggle(PIN_b7);         //  if this works
     putc(boton);
setup_adc_ports(NO_ANALOGS);
  setup_adc(ADC_OFF);
  setup_spi(FALSE);
  setup_psp(PSP_DISABLED);
  setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
  setup_timer_0(RTCC_OFF);
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
  setup_timer_3(T3_DISABLED);
  setup_vref(FALSE);
  port_b_pullups(FALSE);
set_tris_c(0b10000000);
set_tris_b(0b00000000);
output_c(0b00000000);
output_b(0b00000000);
 enable_interrupts(global);
 enable_interrupts(int_rda);
 //lcd_init();
 do {
 if(boton!=0x00)
 } while (TRUE);
Why this does not work?
PostPosted: Sun Feb 01, 2009 6:52 pm     Reply with quote
What is your crystal frequency ? Read the frequency on the crystal
and post it.
mcu
PostPosted: Sun Feb 01, 2009 8:30 pm     Reply with quote
Hi,I am the above message, thanks for your help.
The crystal frequency is 12 Mhz.
Is there something in the code is wrong?
PostPosted: Sun Feb 01, 2009 9:00 pm     Reply with quote
Based on your #fuses statement, the oscillator in the 18F4550 is really
running at 48 MHz. Change your #use delay() statement to this:
#use delay(clock=48000000)
mcu
PostPosted: Mon Feb 02, 2009 8:16 am     Reply with quote
Hi, now works fine. I am very happy. Very Happy
Thank you very much for your help.
