PIN_A4 always 0
PIN_A4 always 0
PostPosted: Mon Feb 02, 2009 3:36 am     Reply with quote
Hi.
What's wrong in this test program?
I am externally switching A4 low-high etc, but code always reads 0, and prints 0. RS232 is working fine as A0 for example with same test works as it should.
Is there something special about A4? I am using PIC16F687. Compiler 4.074.
Thanks. D.
#include "16F687.h"
#device adc=10
#FUSES NOWDT
#FUSES INTRC
#FUSES NOPROTECT
#FUSES NOBROWNOUT
#FUSES NOFCMEN
#FUSES NOCPD
#FUSES NOPUT
#use rs232(baud=9600,parity=N,UART1,bits=8)
#define LED  PIN_C4
   BYTE test;
   setup_uart(1);
   delay_ms(5);
   do
      delay_ms(1);
      test = input(PIN_A4);
      putc(test);
      if (test)
         output_high(LED);
         output_low(LED);
   }while (1);
PostPosted: Mon Feb 02, 2009 4:12 am     Reply with quote
Look at section 3.1 of the data sheet. What does it say RA4 is used for, when you are using the internal oscillator?. What is the difference between the INTRC fuse, and the INTRC_IO fuse?....
PostPosted: Mon Feb 02, 2009 2:28 pm     Reply with quote
Many many thanks. I keep reading the data sheet over and over, and have it open all the time. but little details always get you if you are inexperienced like me. Thanks again
