Manchester Code Reader
Goto page 1, 2  Next
viknes1985
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Thu Jan 22, 2009 9:16 am     Reply with quote
I don't know why the compiler couldn't recognize RBIF, RBIE, PORTB, TMR1IF, TMR1, CARRY, TMR1ON and also the asm. I left out anything? Please help guys. Thanks.[/code]
viknes1985
follow up
PostPosted: Thu Jan 22, 2009 9:17 am     Reply with quote
and the pragma also giving error statement.....
PostPosted: Thu Jan 22, 2009 10:54 am     Reply with quote
Yes, you have to modify the code according to CCS C syntax for interrupt functions and assembly statements. Also the SFR
definitions must be included. The device editor tool can make an include file automaticly.
Generally this kind of code is implementation dependant and not portable between different compilers. CCS C has built-in
functions for most operations in your code, but it works by direct SFR access as well. As with any port of low-level code,
you should check if anything is understood by CCS C correctly.
#include "PIC16F887_registers.h"
#int_RB
void reader(void)
               #asm
                  rlf STAC+7,f
                  rlf STAC+6,f
                  rlf STAC+5,f
                  rlf STAC+4,f
                  rlf STAC+3,f
                  rlf STAC+2,f
                  rlf STAC+1,f
                  rlf STAC+0,f
               #endasm
Where to get registers.h
PostPosted: Sat Jan 24, 2009 1:15 pm     Reply with quote
Thanks for the reply FvM. By the way, where to get "PIC16F887_registers.h", i think i may need "PIC16F877a_registers.h" instead. Is this files are ready made, or i need to create my own *.h header file about the bits on INTCON?
Best Regards
PostPosted: Sun Jan 25, 2009 2:22 am     Reply with quote
viknes1985
My compiler never add the header file
PostPosted: Sun Jan 25, 2009 5:34 am     Reply with quote
Thanks for the reply FvM. Very Happy But i still have errors on undefined identifier for RBIF, RBIE, PORTB, TMR1IF, TMR1, CARRY, TMR1ON. Any idea why my compiler can't compile? By the way, i'm using CCs C Compiler version 4.020
PostPosted: Sun Jan 25, 2009 5:54 am     Reply with quote
The SFR definitions are apparently missing, e.g.:
#byte INTCON = 0x00B
#bit    RBIF = INTCON.0
You can also add these definitions manually, using the SFR addresses from the datasheet. But Device Editor eases this operation, although it creates some double entries, that have to removed to make the file compile correctly.
viknes1985
Minor Problem
PostPosted: Mon Jan 26, 2009 12:25 pm     Reply with quote
I'd include "#include <PIC16F887_registers.h>" and it does reduce the numbers of errors. Thanks to Frank who emailed me this header file. Since TMR1 is 32 bits, it's defined as "#word TMR1 = 0x00E" but the errors pop up saying it's undefined identifier. What's the problem?
Thanks in Advance
PostPosted: Mon Jan 26, 2009 2:17 pm     Reply with quote
The code compiled O.K. with PCM V4.084
viknes1985
Cannot read
PostPosted: Fri Jan 30, 2009 2:40 am     Reply with quote
The codes compiled ok after i upgrade to 4.084. But It's not working.... Maybe my idea was wrong on reading manchester code from U2270. Anyone have better idea on getting series of 1 and 0 from U2270. Sad
viknes1985
Manchester decoding
PostPosted: Sat Jan 31, 2009 11:55 pm     Reply with quote
Can done by fast io.... Using interrupt, it worst the condition
viknes1985
anyone
PostPosted: Fri Feb 06, 2009 9:14 am     Reply with quote
anyone can help me to find where's my code problem. Why it's not working?
PostPosted: Fri Feb 06, 2009 12:07 pm     Reply with quote
Is there any method to get the output in binary form?
See the routines in this thread. They show how to display bytes or words
in binary format (1's and 0's):
http://www.ccsinfo.com/forum/viewtopic.php?t=29265
PostPosted: Fri Feb 06, 2009 12:34 pm     Reply with quote
The binary data display problem has been already clarified in another thread (http://www.ccsinfo.com/forum/viewtopic.php?t=37595), so far the above code is legacy. However, it hasn't been ever said, what the actual problem with the code is supposed to be.
viknes1985
Stuck at here
PostPosted: Wed Feb 25, 2009 10:02 pm     Reply with quote
               #asm
                  rlf STAC+7,f
                  rlf STAC+6,f
                  rlf STAC+5,f
                  rlf STAC+4,f
                  rlf STAC+3,f
                  rlf STAC+2,f
                  rlf STAC+1,f
                  rlf STAC+0,f
               #endasm
this function not seems to work.... is there any other function to rotate this 8 bytes?
can used rotate_left or shift_left
Goto page 1, 2  Next
Page 1 of 2
