qwertyqqqq
use rs232 ;i need help |
Posted: Thu Jan 29, 2009 5:35 am |
I want to compare two char array and if they re the pin b0 is high#include
<16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use rs232 (baud=9600, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1)
int d;
int flag=0;
int flag1=0;
int i=0;
char c;
char yan[20];
char ert[7]={'*','c','e','t','i','n','$'};
#int_rda
void serihaberlesme_kesmesi()
output_low(pin_b0);
c=getch();
putc(c);
if ((flag==0)&& (c=='*'))
flag=1;
if ((c=='$') && (flag==1))
flag=0;
for(d=0;i;d--)
if(yan[i]!=ert[i])
i=0;
flag1=1;
continue;
if ((flag1=1) && (yan[0]='c'))
{output_high(pin_b0);}
if(flag=1)
yan[i]=c;
i++;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
setup_timer_1(T1_DISABLED);
output_low(pin_c5);
enable_interrupts(int_rda);
this is my program can u help me? |
Wayne_
Posted: Thu Jan 29, 2009 6:01 am |
1st of all use the code tags. This makes your code more readable.
Secondly, a char array is basically a string but NOT null terminated, you can still use some of the string functions if you know for sure certain things. If your char arrays have fixed sizes :-
strncmp(str1, str2, 10) will compare the first 10 characters of the 2 strings.
look at the CCS help for more info or search google for strncmp. |
Posted: Thu Jan 29, 2009 4:30 pm |
In the C language you have to use '==' for comparing.
This same error is also in two other locations in your code. |
Posted: Thu Jan 29, 2009 4:57 pm |
ckielstra wrote: | In the C language you have to use '==' for comparing.
Which is why I always put the constant first.
if(flag=1) // will always evaluate to true and leave you with hard to diagnose logic errors.
if(1=flag) // will cause a compiler error as you cannot assign a value to the constant.
Simple thing but ends up making the compiler do a bit of the "proofing" work for you.
Greg |
