PIC18F4620 at 40MHz
murtis
View user's profile Send private message Send e-mail MSN Messenger
PIC18F4620 at 40MHz
PostPosted: Thu Jan 29, 2009 1:02 pm     Reply with quote
How can i drive PIC18F4620 at 40MHz? Could you send me some example_? How can i use the PLL for 40MHz or 32Mhz_?
MurtiS
treitmey
PostPosted: Thu Jan 29, 2009 1:12 pm     Reply with quote
#define FIRM_MAJOR 'E'
#define FIRM_MINOR  1
#define HARD_MAJOR  3
#define HARD_MINOR  3
//#include <18F4525.h>
#include <18F4620.h>
#use delay(clock=40000000, restart_wdt) //note the crystal is 10Mhz
#fuses h4,nowdt,noprotect,nolvp,put   //note h4 is 4x pll must power off to reset pll
#use rs232(baud=19200,xmit=PIN_C0,invert,stream=DEBUG) // stderr(same as debug)
#use rs232(baud=19200,enable=PIN_C5,xmit=PIN_C6,rcv=PIN_C7,stream=CIM)  // rs485 is the default
#case
#zero_ram
#include <flex_lcd.c>  //can be used with lumex S011602 or Optrex DMC16202NYJ
//=== MAIN ===//
  setup_adc_ports(NO_ANALOGS);
  setup_adc(ADC_OFF);
  set_tris_a(0xFF);set_tris_e(0xFF);set_tris_c(0xFF);
  set_tris_b(0xFF);set_tris_d(0xFF);port_b_pullups(TRUE);
  fprintf(DEBUG,"Firm=%C_%03u.c\n\r",FIRM_MAJOR,FIRM_MINOR);
  fprintf(DEBUG,"Hard=%u.%u\n\r",HARD_MAJOR,HARD_MINOR);
PostPosted: Thu Jan 29, 2009 10:04 pm     Reply with quote
Here is another way,
#use delay(clock=40M, oscilator=10M)
The compiler will set the H4 config bit for you....
HTH - Steve H
asmallri
PostPosted: Thu Jan 29, 2009 11:31 pm     Reply with quote
HTH - Steve H
This is version dependent
Regards, Andrew
murtis
PostPosted: Tue Mar 31, 2009 3:46 pm     Reply with quote
HTH - Steve H
I use the ICD-U40 debugger. 10MHz Xtal is used on my hardware design. When i started debugger module on PCWHD, i see the some information at the bottom of the debugger screen that is "Ready MCU at 10.00MHz". My question is that PIC18F4620 is working at 40MHz or 10MHz. Which one is true for me_?
Thanks for your solution offering me....
MurtiS
