kolo Guest
help in pic16f506!!! |
Posted: Wed Jan 28, 2009 3:35 am |
I need help for my codes. I had written codes for my pic16f506 but it doesn't give any output. Please help and my codes in ccs compiler are as shown below. I still do not see any wrong with it. There were no errors when compiled.
#IF defined(__PCB__)
#include <16F506.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOMCLR //Master Clear pin disabled
#FUSES IOSC8 //INTOSC speed 8 MHz
//#byte cm = 0x08
//#use rs232(baud=9600,parity=N,xmit=PIN_B0,rcv=PIN_B0,bits=8)
int16 ch[3];
int i,m,n;
void pread();
void pulse();
void pulser();
void check();
m=0;
//cm=cm&(0x00);
set_tris_c(0);
setup_adc_ports(AN0_AN1_AN2);
setup_adc(ADC_CLOCK_DIV_32);
// setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
while (TRUE)
//output_high(pin_c4);
pread();
check();
if(n==0)
{output_high(pin_c4);
//output_c(~0xFF);
pulse();
else if (n==1)
{output_high(pin_c5);
// output_c(~0xFE);
pulser();
//output_c(~0xFD);
pread();
void pread()
for (i=0;i<3;i++)
set_adc_channel(i);
delay_us(100);
ch[i]=read_adc();
delay_us(100);
void pulse()
if (m==4)
m=0;
output_c((0x01)<<m);
output_c(0x01<<m);
m++;
delay_us(50);
void pulser()
if (m==0)
m=4;
m--;
delay_us(50);
void check()
if ((ch[0]>ch[1])&&(ch[0]>ch[2]))
n=0;
else if ((ch[2]>ch[1])&&(ch[2]>ch[0]))
n=1;
else if ((ch[1]<ch[2])&&(ch[1]<ch[0]))
n=2;
n=3;
Posted: Wed Jan 28, 2009 1:58 pm |
Quote: | #FUSES NOWDT
#FUSES HS
#FUSES NOPROTECT
#FUSES NOMCLR
#FUSES IOSC8 |
Are you using an external 20 MHz crystal, or do you want to use the
internal RC oscillator ?
Also, have you ever made this PIC do anything ? For example, have
you made the PIC on this board blink an LED ? Were you successful ? |
daraos
Posted: Wed Jan 28, 2009 2:07 pm |
shouldn't the functions be outside of Main? |
Posted: Wed Jan 28, 2009 2:14 pm |
His formatting is poor, but the functions are below main(). |
kolo Guest
Posted: Thu Jan 29, 2009 5:05 am |
I found out whats wrong already.
The setup_adc need ADC_CLOCK_INTERNAL to work. Thanks those who spend time reading my messy code. Btw, if I use HS 20 mhz then no need #fuses iosc? Please tell me what is the meaning of poor formatting? I need feedback for improving coding skills. Thanks!!! |
Posted: Thu Jan 29, 2009 4:11 pm |
There are many different indent/brace position styles. This document
lists several of them:
http://en.wikipedia.org/wiki/Indent_style
The main thing wrong with your style is the massive tabbing on some
indents, and lack of indents in other spots.
Also it's easier to read code if the main() code is separated from
functions below it. This could be with some blank lines or a
separator line, such as:
or
It makes it clear where main() ends and the functions begin.
I use separator lines between every function, for clarity. |
kolo Guest
Posted: Thu Jan 29, 2009 7:37 pm |
Thx a lot. What about the #fuses iosc?? If i use #fuses HS for 20 MHz then do i stil need to include #fuses iosc? |
Posted: Thu Jan 29, 2009 7:44 pm |
The PIC data sheet says this:
Quote: | REGISTER 10-2: CONFIG: CONFIGURATION WORD REGISTER
IOSCFS: Internal Oscillator Frequency Select bit
1 = 8 MHz INTOSC speed
0 = 4 MHz INTOSC speed |
That bit controls the internal oscillator speed. Since you're using an
external crystal in HS mode, the internal oscillator is not used.
It doesn't matter what the speed setting is for it. So you shouldn't
need to specify the IOSCx fuse. |
kolo Guest
Posted: Thu Jan 29, 2009 8:50 pm |
Thanks a lot!!! |
