Adding debounce into my program
orgee
PostPosted: Wed Jan 28, 2009 10:26 am     Reply with quote
Hi, I'm newbie in PIC programming. I'm trying to design an infrared sensor with LED output. The program work but i want to upgrade with 'debounce' condition. Anybody can help how to integrate 'debounce' into my program?
#include <16f877a.h>
#use delay (clock = 20000000)
#fuses hs,noprotect,nowdt,nolvp
#BYTE PORTA=5
#BYTE PORTB=6
#BYTE PORTC=7
#BYTE PORTC=8
   set_tris_b (0xff);
   set_tris_c (0);
   portc = 0b0000000; //initial condition
         do
            if (portb == 0b00000001) //LED left
            portc = 0b00000001;
            if (portb == 0b00000100) //LED right
            portc = 0b00000010;
            if (portb == 0b00000010) //LED both
            portc = 0b00000011;
         while(true);
daraos
PostPosted: Wed Jan 28, 2009 10:43 am     Reply with quote
an easy way to do it is to check the buttons every 10 ms, and activate the leds when the program detects the button presed twice in a row... something like:
int left_led;
do{
            delay_ms(10);
            if (portb == 0b00000001) left_led++; //LED left
            else left_led=0;
            if(left_led>2) left_led=2;
            if(left_led==2) portc = 0b00000001;
you have to add the code for the rest of the leds.
Not the most elegant solution, but for something as simple as this, it will do the task.
For something more complex, you can have an interrupt checking the inputs, using the same logic.
EDIT:
an enhancement in the code would be to check individual pins from the port, using
          if(input(pin_b0)) //to check the pin
                 OUTPUT_HIGH(pin_c0);  //to set the pin
                 OUTPUT_LOW(pin_c0);
Doing it this way, you don't need to make all the combinations of ON and OFF buttons.
Of course, you'll have to apply the debouncer function to this, but it should be easy now Wink
Cheers[/code]
rnielsen
PostPosted: Wed Jan 28, 2009 12:41 pm     Reply with quote
Check out my post at http://www.ccsinfo.com/forum/viewtopic.php?t=24103 to see if this might be something you can use.
Ronald
