USART Transmit Problems
rhaguiuda
PostPosted: Wed Jan 28, 2009 7:17 am     Reply with quote
Hi.
This is not the first time I've seen this bug. Don't know why it happens.
When trying to make a simple program that sends a sequence through USART:
   printf ("Teste");
   putc(0x7E);
If I use this sequence, the computer shows only some words. PIC never sends all chars. Usually stops at "t".
The only way to receive the complete sequence of chars is putting a delay of some time after the code, just like this.
   printf ("Teste");
   putc(0x7E);
   delay_ms (100);
I'm using a PIC18F876, with a 4 MHz crystal. PCM 4.084.
Fuses:
#fuses XT, PUT, NOWDT, NOLVP
#use delay(oscillator=4M)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7,errors)
Does anyone know about this problem?
Give a man a fish and you'll feed him for a day. Teach a man to fish, and you'll feed him for a lifetime.
PostPosted: Wed Jan 28, 2009 9:28 am     Reply with quote
You don't show the rest of the program, but I'd guess there is a simple key thing missing.
void main(void) {
   //setup code here to initialise the chip peripherals as needed
   printf ("Teste");
   putc(0x7E);
This _will_lose the last two characters.
void main(void) {
   printf ("Teste");
   putc(0x7E);
   while(TRUE);
This _won't_.
The key is understanding, that when you write a program like this on a PC, there is a complete operating system running 'outside' the program. When the program terminates, it can leave the OS to 'get on' with housekeeping outside. However written on the PIC, _there is nothing but the code you write_. Now in the first case, there are two characters in the hardware transmit buffer, when the program terminates. The processor then basically stops (it actually goes to sleep), so these characters are lost. In the second, the code _remains running_, so the characters are sent.
What you are doing, is 'running off the end' of the code. Don't. You should stay inside the program at all times, and write code to handle everything.
