Andrew83
| Serial translation question ! |
Posted: Tue Jan 27, 2009 3:25 am |
Hello !
Here is what i'm trying to do :
Let's say i have a character transmitted from serial like 0xAA (binary : 10101010).
I want to translate this command into : 0x3AA (binary : 1110101010).
How can this be done ?
Should i use a cast it to int, like this :
char c;
int d;
d=(int)c*
Thank you all ! |
Andrew83
Posted: Tue Jan 27, 2009 4:58 am |
Here is a small test code that isn't working:
#include <18f452.h>
#use delay(clock=10000000)
char c;
int d;
c=getc();
d=(int)c*;
printf("%ld",d);
In the CCS c manual :
| Quote: |
getc( ) .... Returns: An 8 bit character |
HELP !!!!!!!! |
Posted: Tue Jan 27, 2009 5:47 am |
int is a 8-bit bit value in the CCS compiler.
why do you cast the value (btw cast with * cant work in your example)? what about
c=getc();
printf("%u",c); |
Wayne_
Posted: Tue Jan 27, 2009 6:19 am |
not sure what you are trying to do with c*
int is 8 bits on a pic.
try int16
char c;
int16 d;
c = getc();
d = (int16)c + 0x300;
printf("%ld",d);
LOL, distracted while typing my post so didn't see Guest post  |
Andrew83
Posted: Tue Jan 27, 2009 12:41 pm |
| Thank you 4 your quick answer ! ;) |
