designing with LCD 16x2 and switch for user interface
david90
PostPosted: Thu Jan 22, 2009 2:50 pm     Reply with quote
I'm designing a circuit with three functions and I'm using a 16x2 LCD with some switches so that I can select one of the three function. The LCD would display the selected function and it's setting. I can use the switch to change between the three functions or change the function's setting.
My question is where in my program should I put the code for my switch and LCD? How should I structure my code when using LCD and switches for user interface?
I hope I'm making sense.
Thanks!
david90
PostPosted: Sat Jan 24, 2009 1:17 am     Reply with quote
I need to know if my method of using an LCD for user interface is good. Is there a better way to program this? So far the code works and I could change the duty cycle but I also want to be able to change the frequency also using the same inputs pin.
#include <16F877.H>
#use delay(clock = 4000000)
#include "flex_lcd.c"
#include "lcd_registers.c"
lcd_init();
      delay_ms(50);
      if (input_state(PIN_B0))
         increase_duty(1);
      if (input_state(PIN_B1))
         increase_duty(0);
#Define PWM_label1 "[PWM]"
#Define PWM_label2 "Duty%:"
#Define PWM_label3 "Freq:"
int duty_cycle=50;
int frequency=1000;
void lcd_output()
   lcd_send_byte(0, 1);
   printf(lcd_putc,"%s %s%u\n%s%u",PWM_label1,PWM_label2,duty_cycle, PWM_label3,frequency);
void increase_duty(int1 c)
   if (c)
      if(duty_cycle!=100)
         duty_cycle=duty_cycle+1;
         lcd_output();
      if(duty_cycle!=0)
         duty_cycle=duty_cycle-1;
         lcd_output();
david90
PostPosted: Sat Jan 24, 2009 10:18 pm     Reply with quote
Any comments on my code architecture?
PostPosted: Sun Jan 25, 2009 3:54 pm     Reply with quote
The reason no one wants to answer is because you want a full-blown LCD menu system. That's not a trivial thing to code.
david90
PostPosted: Mon Jan 26, 2009 1:48 am     Reply with quote
Is there an existing example of a menu system code then?
dyeatman
PostPosted: Mon Jan 26, 2009 6:52 am     Reply with quote
Here is one example found by searching this forum that shows how to set
up a menu. It does not show the user input code.
http://www.ccsinfo.com/forum/viewtopic.php?t=30610
