30f4013 as i2c slave (solved and another weird problem)
on7nh
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Sat Jan 24, 2009 2:34 pm     Reply with quote
hey,
can anybody provide me with a example to set up a 30f4013 as i2c slave?
how to set up the interrupt routine ?
on7nh
PostPosted: Sun Jan 25, 2009 5:56 am     Reply with quote
i have now communication,
my master code :
//   DS_plasma voeding date 07/12/2008
#include <30f4013.h>
#device adc=12
#FUSES NOWDT // Watch Dog Timer
#FUSES HS2_PLL16
#FUSES PR_PLL //Promiary Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES DEBUG //No Debug mode for ICD
#FUSES ICS0 //ICD communication channel 0
#use delay(clock=128000000)
#use rs232(baud=19200, UART1A)
#use i2c(Master,sda=PIN_F2,scl=PIN_F3,FORCE_SW,SLOW) // hw I2C
#include <math.h>
   setup_adc_ports(ALL_ANALOG);
    setup_adc(adc_clock_internal);
     printf("test\n");
   Prnt_display();
    // Inlezen Potentiometer Freq
         set_adc_channel(0);
         delay_ms(10);
         freq=read_adc();
   // Inlezen Potentiometer Power
         set_adc_channel(1);
         delay_ms(10);
      //   dutycyl=read_adc();
         power=read_adc();
   // Inlezen Gemeten Spanning
         set_adc_channel(2);
         delay_ms(10);
         MeasU=read_adc();
   // Inlezen Gemeten Stroom
         set_adc_channel(3);
         delay_ms(10);
         MeasI=read_adc();
      Prnt_display();
void Prnt_display()
         //write ingestelde frequentie
i2c_stop();
               i2c_start();
            i2c_write(0xb0);
               i2c_write(200);
            i2c_write(205);
            i2c_write(104);
            i2c_stop();
code slave :
#device adc=12
#FUSES HS2_PLL16
#use rs232(baud=115200, UART1A)
#use i2c(SLAVE, SDA=PIN_F2, SCL=PIN_F3, address=0xb0)
#include <math.h>
   unsigned int16  measU,   measI;
   unsigned int16   Power, bargraph;
   unsigned int16 freq;
   unsigned int dyc;
   void Prnt_display();
   int16 keyw;
      int incoming, state;
   BYTE B1, B2, B3, B4;
float dutycyl;
#INT_SI2C
void SI2C_interupt ()
      state = i2c_isr_state();
//printf("state %u\n\r  ",state);
    if(state <= 0x80)                     //Master is sending data
      incoming = i2c_read();
         if(state == 1)
            b1 = incoming;
printf("Inc1 %u\n\r  ",incoming);
         if(state == 2)
            b2 = incoming;
printf("Inc2 %u\n\r  ",incoming);
         if(state == 3)
            keyw = incoming;
printf("Inc3 %u\n\r  ",incoming);
      // toekennen i2c data
       if(keyw == 101)
         power = make16(b2,b1);
         keyw = 0;
       if(keyw == 102)
         MeasU = make16(b2,b1);
         keyw = 0;
       if(keyw == 103)
         MeasI = make16(b2,b1);
         keyw = 0;
       if(keyw == 104)
         Freq = make16(b2,b1);
//printf("Inc %u\n\r  ",incoming);
      //   printf("I2c freq  %u\n\r  ",freq);
         keyw = 0;
       if(keyw == 105)
         bargraph = make16(b2,b1);
         keyw = 0;
   if(state == 0x80)                     //Master is requesting data
//      i2c_write(buffer[address]);
      char selection;
      setup_compare(1, COMPARE_PWM | COMPARE_TIMER2);
   setup_adc_ports(NO_ANALOGS);
//    setup_adc(adc_clock_internal);
   enable_interrupts(intr_GLOBAL);
   enable_interrupts(int_SI2C);
   enable_interrupts(int_MI2C);
   dutycyl = 10;
         dutycyl = freq;
         setup_timer2(TMR_INTERNAL | TMR_DIV_BY_1, 2000);
         //dutycyl = 1000;
         dyc =(ceil(2000-(2000*dutycyl/4000)));
      //   printf("dyc  %u         freq  %u\n\r  "dyc,freq);
         set_pwm_duty(1,dyc); // This sets the time the pulse is
After the I2C_read command I print now for debugging,
address is 0Xb0 because there is also another slave with address 0xa0 (pic18f452)
Isr_state is incrementing every time I write to the slave.
but I receive always 255 in I2C_read.
Shocked Shocked Shocked
Any suggestions?
ps to CCS.....why is in the PCD manual still wrong about the interrupts ?
Int_SSP is not possible in 30F Confused .....
