Code problem with function pointers !
rougie
PostPosted: Fri Jan 23, 2009 11:49 pm     Reply with quote
Can someone point out why I am getting an error in this simple code fragment?
#include <Dv4685.h>              // DEVICE INNITIALIZATIONS
#include <stdlib.h>              // CCS LIBRARY STANDARD LIBRARY
int sum(int a, int b);
int subtract(int a, int b);
int mul(int a, int b);
int div(int a, int b);
int (*p[4])(int x, int y);
  int result;
  int i, j, op;
  p[0] = sum; /* address of sum() */
  p[1] = subtract; /* address of subtract() */
  p[2] = mul; /* address of mul() */
  p[3] = div; /* address of div() */
  op = 1;
  result = (*p[op]) (i, j);
  return a + b;
  return a - b;
  return a * b;
  if(b)
      return a / b;
      return 0;
All help appreciated!
Rob
PostPosted: Sat Jan 24, 2009 12:18 am     Reply with quote
Always post:
1. Your PIC.
2. The compiler version.
3. The error message.
4. Indicate the line of code in your program that has the error.
MicroManiac
View user's profile Send private message Send e-mail MSN Messenger
Re: Code problem!
PostPosted: Sat Jan 24, 2009 12:28 am     Reply with quote
Well first of all, I'm not sure that this is the right way to return an array in a function call
you should try:
int *p(int x, int y);
Second
p[0] = sum
this is not the way to call a function.
in the function prototype, you specified that you need parameters
this can cause the error. try
p[0] = sum(i,j);
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein
rougie
PostPosted: Sat Jan 24, 2009 8:58 am     Reply with quote
>Well first of all, i'm not sure that this is the right way to return an array >in a function call
>you should try:
http://www.java2s.com/Code/C/Function/Initializethefunctionpointerarray.htm
standing by!
rougie
PostPosted: Sat Jan 24, 2009 9:04 am     Reply with quote
ooops!
I meant:
http://www.java2s.com/Code/C/Function/ArraysofPointerstofunctions.htm
But I see that it is declared in main() !!!!
Let me try something!
I'll get back!
FvM
PostPosted: Sat Jan 24, 2009 10:05 am     Reply with quote
See CCS C manual:
The compiler does not permit pointers to functions.
Best regards,
Frank
PostPosted: Sat Jan 24, 2009 1:10 pm     Reply with quote
That note is probably not up date. Function pointers do work at least
on 18F, but they require a late version, and sometimes require a work-
around. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=33458
I don't guarantee that they can be made to work in an array of
function pointers. It would require testing.
rougie
PostPosted: Sat Jan 24, 2009 4:14 pm     Reply with quote
Disappointing!
Robert
FvM
PostPosted: Sat Jan 24, 2009 6:13 pm     Reply with quote
That note is probably not up date. Function pointers do work at least on 18F, but they require a late version, and sometimes require a work-around.
Yes, surprisingly. Unfortunately, no CCS doc mentions it. Readme.txt, said to contain the latest updates to the compiler hasn't a word on it. So there is an interesting question: Does the compiler manual and supplementing dóc mean anything?
I found, that array of function pointers seems to be supported rather straightforward. I didn't check code operation, but it looks meaningful from the assembly listing.
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
void funct1(int8 par1)
printf("Hello Funct1 %i\n\r",par1);
void funct2(int8 par1)
printf("Hello Funct2 %i\n\r",par1);
// Typedef a function pointer.
typedef void (*_fptr)(int8);
int8 i;
_fptr fptr[2] = {funct1,funct2};
for (i=0;i<2;i++)
  (*fptr[i])(10+i);
rougie
PostPosted: Sun Jan 25, 2009 10:39 am     Reply with quote
Thanks FvM!
Your sample code regarding arrays of function pointers works!
I am using PCWH version : 4.083
Thanks again!
Roberto
