s7en Guest
| LCD Hardware not working properly |
Posted: Thu Jan 22, 2009 2:06 am |
Hi, I'm running a program for LCD (as below). The simulation working properly but when running on hardware the display appear intermittently. Most of the times LCD show full block display on first row. I need to touch the IC leg 1 and 2 and suddenly the display appear.
Please help!
| Code: | #include <16f877a.h>
#use delay (clock = 20000000)
#fuses hs,noprotect,nowdt,nolvp
#BYTE PORTA=5
#BYTE PORTB=6
#BYTE PORTC=7
#include <flex_lcd.c>
set_tris_a (0);
lcd_gotoxy(1, 1);
lcd_putc("VOTE\n");
lcd_putc("READY\n");
int8 value;
value = input_b();
switch(value)
case 0b00000001: lcd_putc("Yes"); break;
case 0b00000011: lcd_putc("No"); break;
Posted: Thu Jan 22, 2009 2:22 pm |
| Quote: | | I need to touch the IC leg 1 and 2 and suddenly the display appear | .
1. On the LCD, those pins are the Ground and Power pins. On the PIC,
pin 1 is the MCLR pin. You need to fix your hardware. Check the wires
and make sure you have good connections. Make sure you have a
pull-up resistor on the MCLR pin of the PIC.
2. The lcd advances the cursor after each character is displayed with
the lcd_putc() function. After a few characters are displayed in your
while() loop, the LCD cursor will be off the screen. You need to reset
the cursor to coordinates (1, 1) at the start of the while() loop. |
Posted: Fri Jan 23, 2009 12:56 am |
| thanks! i wired wrong to MCLR. The problem solved. |
