PIC restarting when connected with ENC28J60
Goto page 1, 2  Next
leejok2003
PostPosted: Tue Jan 20, 2009 11:44 am     Reply with quote
I am still stuck with the PIC18F4620+ENC28J60 TCPIP project, again. I have discover a problem:
1. When I programmed CCS TCPIP stack, example 10b, which have the ICMP function into 18F4620, without any power supply (power supply is source from PIC's 5v to 3.3v voltage regulator) to ENC28J60, the PIC seems working and display the message "CCS TCPIP STACK EXAMPLE10B...". But when i supply the power to ENC28J60, the PIC begins to reset and reset and stay in the loop. I have check pin 1 at PIC, the voltage is 5v and ENC is running at 3.3v. I have tried disconnect all the connection between PIC and ENC, but when I supply the power to ENC, the PIC begin turned reset like in a loop.
Does anyone have any idea??? I am building the CCS TCPIP development board without the LCD and EEPROM model.
PostPosted: Tue Jan 20, 2009 2:47 pm     Reply with quote
Look at the power supply voltage on the Vdd pins of the PIC.
The Vdd level is probably being pulled down below the BROWNOUT
voltage setting, and the PIC then resets.
asmallri
Re: PIC restarting when connected with ENC28J60
PostPosted: Tue Jan 20, 2009 3:48 pm     Reply with quote
leejok2003 wrote:
Is your on-board power supply capable of delivering 200mA at 3.3 volts to the ENC28J60?
Do you have large power supply filter capacitors before and after the 3.3 volt regulator to supply the large transient currents produced by the ENC28J60?
Regards, Andrew
leejok2003
PostPosted: Wed Jan 21, 2009 2:12 am     Reply with quote
How to check the BROWNOUT setting?
PostPosted: Wed Jan 21, 2009 2:26 am     Reply with quote
Look at your #fuses statement. Do you have any of these settings in it ?
BROWNOUT, BORV21, BORV28, BORV43, BORV46
Also look at the end of the .LST file for your project. It shows the Config
bits generated by the compiler. You can see what the settings are for
Brownout.
Also, tell us about your power supply circuit, as asmallri suggests.
Post the part numbers of the voltage regulator ICs used on your board.
leejok2003
PostPosted: Wed Jan 21, 2009 2:50 am     Reply with quote
i have found something on my board when testing it:
If i would have connect a LED to the SO pin of the ENC28J60 chip, it can be ping sucessfully but with losses. It can stop the PIC restarting, but the communication is unstable. Any ideas?
leejok2003
PostPosted: Wed Jan 21, 2009 3:12 am     Reply with quote
Brownout.
i did't have those fuse in the source code. The voltage regulator IC i am using is LM3940 from NS, which outputs 1A.
leejok2003
PostPosted: Wed Jan 21, 2009 4:24 am     Reply with quote
asmallri wrote:
leejok2003 wrote:
I have one with 0.47uF for input voltage and 22uF for output voltage
asmallri
PostPosted: Wed Jan 21, 2009 7:05 am     Reply with quote
leejok2003 wrote:
This implies there may be something wrong with your SPI bus implementation - the LED appears to be functioning as a pull-up resistor.
Regards, Andrew
leejok2003
PostPosted: Wed Jan 21, 2009 7:37 am     Reply with quote
Hi asmallri,
If the situation is like that, how to fix it? Can you give me some idea of it? Thanks...
So sad that i only have 1 PIC working with the PING and i have forgot the configuration of it!!! Now trying back to bring back the solution so that i can go futher...hopefully Crying or Very sad
asmallri
PostPosted: Wed Jan 21, 2009 8:06 am     Reply with quote
leejok2003 wrote:
Hi asmallri,
If you have copied the circuit from elsewhere then I would check to see if you have copied it correctly. If it is your own circuit then post the schematic.
HOWEVER the most important piece of this is still your power supply circuitry including the type of power source, regulator circuit, power supply filter capacitors and decoupling capacitors. ANY of these can cause the problems you are describing.
Regards, Andrew
leejok2003
PostPosted: Wed Jan 21, 2009 8:29 am     Reply with quote
The circuit bellow is which i am working on it:
1. The connection to RJ45 is not shown.
2.The power supply for ENC28J60 is shown which uses 5v input from 5v regulator.
3.The capacitor value is as shown.
4. The WOL' pin is not shown in the circuit.
[img]http://www.freeimagehosting.net/image.php?6d64b9c464.jpg[/img]
asmallri
PostPosted: Wed Jan 21, 2009 9:00 am     Reply with quote
Hopefully you have an additional 100uF or similar capacitor on the input of the regulator which is not shown.
Regards, Andrew
andrewg
PostPosted: Sun Jan 25, 2009 7:16 am     Reply with quote
The ENC28J60 is supposed to have ceramic 0.1uF caps on all the VDD/VSS pairs, including the OSC, RX, TX, and PLL pairs (total five pairs). I can't see a 0.1uF bypass cap for your PIC, either.
Also, you should read the errata for the ENC28J60, there are some issues relating to the SPI bus speeds. I forget the details (I've misplaced my errata files), but I've always used one of the recommended workarounds which is to use the ENC CLKOUT to clock the PIC.
Andrew
asmallri
PostPosted: Sun Jan 25, 2009 7:41 am     Reply with quote
For early rev ENC28J60s you had to have the SPI speed at 8MHz or above.
Regards, Andrew
Goto page 1, 2  Next
Page 1 of 2
