weird readings in a HMC6352
Memristor
PostPosted: Fri Jan 16, 2009 8:18 am     Reply with quote
hi!
I bought a digital compass, the hmc6352, it works fine.
I changed the operational mode, and then i try to read it from the EEPROM and from the RAM, but i get weird numbers like 12, 3, 4,
(I expect 82=0x52);
#include <16F873A.h>
#fuses HS, NOPROTECT, NOWRT, NOLVP
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)
void changemode(){
int raam;
i2c_start();
i2c_write(0x42);
i2c_write(0x47);//write to RAM
delay_us(80),
i2c_write(0x74);//RAM address
delay_us(80);
i2c_write(0x52);//continuous operational mode (0b01010010)
i2c_stop();
delay_us(80);
i2c_start();
i2c_write(0x42);
i2c_write(0x67);//read from RAM
delay_us(80);
i2c_stop();
delay_us(80);
i2c_start();
i2c_write(0x43);
raam=i2c_read();
i2c_stop();
printf(" RAM: %u\n\r", raam);
i2c_start();
i2c_write(0x42);
i2c_write(0x4C); //save mode
i2c_stop();
delay_us(130);
void readmode(){
int ee;
i2c_start();
i2c_write(0x42);
i2c_write(0x72); //read from EEPROM
delay_us(80);
i2c_write(0x08);//EEPROM address
i2c_stop();
delay_us(80);
i2c_start();
i2c_write(0x43);
ee=i2c_read();
i2c_stop();
printf(" EEPROM: %u\n\r", ee);
void main(){
  setup_adc_ports (NO_ANALOGS);
  setup_adc (ADC_OFF);
  setup_spi (SPI_SS_DISABLED);
  setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_1);
  setup_timer_1 (T1_INTERNAL | T1_DIV_BY_8);
  setup_timer_2 (T2_DISABLED, 0, 1);
  setup_comparator (NC_NC_NC_NC);
  setup_vref (FALSE);
changemode(); //first I change the mode and then i read it
while(true){
   readmode();
thanks!
PostPosted: Fri Jan 16, 2009 12:49 pm     Reply with quote
I didn't look at your code too closely, but I did notice that you're not
giving a NACK on the last read operation. You need to do that.
Add a 0 parameter to i2c_read() statement as shown below:
i2c_start();
i2c_write(0x43);
raam=i2c_read(0);
i2c_stop();
There are two places in your code (in total) where this needs to be done.
