Problem in BYTE stream data transmission through UART
mlkushan
PostPosted: Thu Jan 15, 2009 11:18 pm     Reply with quote
Hi all,
I'm doing a wireless sensor network based project. Here i needs to send a packet from source to destination. Packet format is mentioned bellow with example values for each segment of the packet and size of the each field (field, example value, size).
Destination address 0x55 1 byte
source address 0x00 1 byte
Final Destination address 0x55 1 byte
Originator Address 0x00 1 byte
Packet Type 0x00 1 byte
Hop Count 0x00 1 byte
Payload length 0x00 1 byte
Payload AA 4 byte
Ending Delimiter 0x7FF 1 byte
There is no problem in serial communication between the source and the destination. it works perfectly.
But at the destination end packet is drop by the program. due to some data modification of the packet. What i mean by modifications is the byte stream send by the sender is not captured correctly. when i send 0x00,0x00,0x00,0x00,0x00,0x00,0x00,AA,0x55,0x7FF as the byte stream. the receiver interpret it as 1010302-86-21-2. So that implies the packet has been modified.
Then the packet is drop by below mention code segment of the receiver program. If the data has been correctly transferred without any modification, "Rx_buffer[0] != Ended)" or "(Rx_buffer[0] != Broadcasts" should be true.
So I couldn't figure out the exact reason to the above mention problem.
For simplicity i post the entire code here. Sender code is a testing code which i use for testing.
So please help me to figure out the problem here while transmitting the hexadecimal values in the byte stream.
Thank you very much everyone. Any help is highly appreciated.
Kushan
if(data_avail)
if((rx_buffer[0] != EndDevAdd01) || (rx_buffer[0] != BrdcastAdd)){
            memset(rx_buffer,0,sizeof(rx_buffer));           //drop the rx packet
            printf("Drp:\n");   //Print for testing purposes only
Data Packet Transmitter code;
#include <16F877A.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES NOPUT                    //No Power Up Timer
#FUSES WRT_50%                  //Lower half of Program Memory is Write Protected
#include <stdio.h>
#include <stdlib.h>
#include <stdlibm.h>
#include <string.h>
//for routting algorithm
#define CoordntrAdd 0x00 //Defining the Address of the Coordinator
#define RouterAdd01 0x81 //Address of this Router device
#define BrdcastAdd 0xFF
#define EndDevAdd01 0x01 //Addresses of End Devices
#define EndDevAdd02 0x02 //Addresses of End Devices
//for RXTX data communication
#define RX_BUFFER_SIZE 12
#define TX_BUFFER_SIZE 12
#define DELIM 0xFE      //since we are using bytes
#byte TXREG=0x19
#byte PIR1 = 0x0c
#bit TXIF=PIR1.4
//unsigned int8 rx_buffer[RX_BUFFER_SIZE + 1];
unsigned int8 tx_buffer[TX_BUFFER_SIZE + 1];
//int8 rx_wr_index = 0;
int8 tx_rd_index = 0;
int8 tx_wr_index = 0;
int8 tx_counter = 0;
//int8 rxd;
//int1 data_avail = FALSE;
#int_TBE
void TBE_isr(void) {
   if (tx_counter != 0) {
      putc(tx_buffer[tx_rd_index]);
      if (++tx_rd_index > TX_BUFFER_SIZE) {
         tx_rd_index = 0;
      tx_counter--;
      if (tx_counter == 0) {
         disable_interrupts(INT_TBE);
void bputc(int c) {
   int restart = 0;
      restart = 1;
   tx_buffer[tx_wr_index++] = c;
   if (tx_wr_index > TX_BUFFER_SIZE) {
      tx_wr_index = 0;
   tx_counter++;
   if (restart == 1) {
      enable_interrupts(INT_TBE);
void main(){
   int8 a;
   unsigned int8 packet[10];
   delay_ms(2000);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //enable_interrupts(INT_RDA);
   while(true){
         packet[0] = EndDevAdd01;  //destination
         packet[1] = CoordntrAdd;  //source
         packet[2] = EndDevAdd01;  //final destination
         packet[3] = CoordntrAdd;  //originater
         packet[4] = 0x03;  //packet type
         packet[5] = 0x00;  //hopcount
         packet[6] = 0x02;  //payload length
         packet[7] = 0xAA;  //AC on state
         packet[8] = 0x15;  //AC on signal
         packet[9] = DELIM; //ending delimeter
         for(a=0;a<10;a++){
            bputc(packet[a]);
         delay_ms(5000);
         packet[0] = BrdcastAdd;  //destination
         packet[1] = EndDevAdd02;  //source
         packet[2] = BrdcastAdd;  //final destination
         packet[3] = EndDevAdd02;  //originater
         packet[4] = 0x04;  //packet type
         packet[8] = 0x16;  //AC on signal
         for(a=0;a<10;a++){
            bputc(packet[a]);
         delay_ms(5000);
Data Packet Receiver code;
#device adc=8
#include <math.h>
#include <string.h>
//function prototypes
void sendData(int8 envTemp, int8 packetType, int8 *packet);
void payloadDecipher(unsigned int num_rounds, unsigned int8* packetPayload);
void payloadEncipher(unsigned int num_rounds, unsigned int8* packetPayload);
void createPacket(int8 packetType, int8 payloadLength, int8 *packet);
//For encryption and decryption
unsigned int8 key[] = {0x80, 0x00, 0x80, 0x80};    //32bit int8 key of for XTEA
//define the packet payload array pointer
int8 *packetPayload;
//Array for keeping routing entries
//route_table[0] for keeping the nexthop address
//route_table[1] for keeping the hopcount
int8 route_table[2];
//mainteains the Air Conditioner state
int1 AC_State = FALSE;
#byte TXREG=0x19
#byte PIR1 = 0x0c
#bit TXIF=PIR1.4
int8 rxd;
//Define AC state
#define ACStateON 0xAA
#define ACStateOFF 0xBB
//SPI communication parameters
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)   //    low       leading edge
#define SPI_MODE_1  (SPI_L_TO_H)                     //    low       trailing edge
#define SPI_MODE_2  (SPI_H_TO_L)                     //    high      leading edge
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)   //    high      trailing edge
#int_RDA
void RDA_isr(void) {
   rx_buffer[rx_wr_index] = getc();
   rxd = rx_buffer[rx_wr_index];
   rx_wr_index++;
   if(rxd==DELIM){
      data_avail = TRUE;
      rx_wr_index = 0;
   if (rx_wr_index > RX_BUFFER_SIZE) {          //prevent buffer overflows
      rx_wr_index = 0;
#int_TBE
         tx_rd_index = 0;
      tx_counter--;
void bputc(int c) {
   int restart = 0;
   if (tx_counter == 0){
      restart = 1;
      tx_wr_index = 0;
   tx_counter++;
   if (restart == 1){
void setIrCommand(int8 ACState, int8 tempValue){
   if(ACState == ACStateON){
      spi_write(0x32);         //set AC ON
   else if(ACState == ACStateOFF){
      spi_write(0x64);         //set AC OFF
   else if((tempValue > 0x16) && (tempValue < 0x31)){
      spi_write(tempValue);      //set temperature value here.
void main(){
   int8 pwmDuty = 50;
   int8 counter = 0;
   int8 envTemp;
   int8 *rxPcketPayload;
   int8 a;
   int8 packet[12];
   //delay_ms(2000);   //initializing delay
   setup_adc_ports(AN0);
   //set_tris_a(0b00000001);
   delay_us(100); //This ensures the slave has time to wake before master
   setup_spi(SPI_MASTER|SPI_MODE_0|SPI_CLK_DIV_4);
   delay_us(100);
   setup_timer_2(T2_DIV_BY_1,24,1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(pwmDuty);
   setup_vref(FALSE);
   route_table[1] = 0xFF; // First initialise the hop count to the largest value.
   while(true){
      //packet listener code
      if(data_avail)
         data_avail = FALSE;
         printf("DA:%d\n",rx_buffer[4]);   //Print for testing purposes only
         else{
            switch(rx_buffer[4]){ // switch the packet type
               case 0x01:  // Route request packet
                  if(route_table[1] > rx_buffer[5]){    //check the hop count value of the incoming packet
                     route_table[0] = rx_buffer[1];     // Nearest source's address
                     route_table[1] = rx_buffer[5];     // update the hop count
                  printf("Rqst:\n");  //Print for testing purposes only
                  createPacket(0x02, 0x00, packet);     // Send a route reply packet
               case 0x02: // Route reply packet, from others, shold be droped
                  printf("Othr:\n");   //Print for testing purposes only
                  // Drop the packet
               case 0x03: // Data packet from the cordinator
                  rxPcketPayload = (int8 *)calloc(rx_buffer[6], sizeof(int8));  //allocate memory of the size of incoming packet payload length to store the incoming data
                  for(a = 0; a < rx_buffer[6]; a++){
                     *(rxPcketPayload + a) = rx_buffer[(7 + a)];      //store the payload into rxPcketPayload
                  for(a = 0; a < rx_buffer[6]; (a += 2)){
                     payloadDecipher(32,(rxPcketPayload + a));        //decrypt the packet here
                  //first byte of the payload is the ACState and the second byte of the payload is the tempValue
                  setIrCommand(*rxPcketPayload, *(rxPcketPayload + 1));
                  free(rxPcketPayload); //free the alocated memory
                  printf("Data:\n");   //Print for testing purposes only
               case 0x04: // Emergency
                  set_adc_channel(0);        //the next read_adc call will read channel0. This is needed when there are more analog inputs
                  envTemp = read_adc() * 500/1024;
                  envTemp = floor(envTemp);
                  printf("Emrg:\n");  //Print for testing purposes only
                  sendData(envTemp, 0x04, packet);                 //send emergency data packet
      //End of packet listener code
      else if(counter == 60){       //if the counter equals to 2000 it reads the temperature value from the sensor
         counter = 0;            //Again set the counter to zero
         sendData(envTemp, 0x03, packet);             //send data packet to the cordianter which contains environment temperature
      counter++;      //set the counter here as a timer
void payloadEncipher(unsigned int num_rounds, unsigned int8* packetPayload){
   unsigned int8 fblock, sblock, i, sum=0;
   unsigned int8 delta=0x9E3779B9;
   fblock = *packetPayload;
   sblock = *(packetPayload + 1);
   for(i=0; i<num_rounds; i++) {
      fblock += (((sblock << 4) ^ (sblock >> 5)) + sblock) ^ (sum + key[sum & 3]);
      sum += delta;
      sblock += (((fblock << 4) ^ (fblock >> 5)) + fblock) ^ (sum + key[(sum>>11) & 3]);
   *packetPayload = fblock;
   *(packetPayload + 1) = sblock;
void payloadDecipher(unsigned int num_rounds, unsigned int8* packetPayload) {
   unsigned int8 fblock, sblock, i, sum;
   sum=delta*num_rounds;
      sblock -= (((fblock << 4) ^ (fblock >> 5)) + fblock) ^ (sum + key[(sum>>11) & 3]);
      sum -= delta;
      fblock -= (((sblock << 4) ^ (sblock >> 5)) + sblock) ^ (sum + key[sum & 3]);
// Function to create the data packet
void createPacket(int8 packetType, int8 payloadLength, int8 *packet){
   int8 a = 0;
   if(packetType == 0x04){  //for emergencey packet
      packet[0] = BrdcastAdd;      //add the broadcast address to send the packet
   else{         //for normal data packet or router reply packet (sends to the cordinator)
      packet[0] = route_table[0];      //add the nearest destination address to send the packet
   packet[1] = EndDevAdd01;       //add the source address to the packet
   packet[2] = CoordntrAdd;     //add the final destination address(cordinator)
   packet[3] = EndDevAdd01;     //add the originator node address  to the packet
   packet[4] = packetType;    //set the packet type here
   packet[5] = 0x00;        //set the hop count here
   packet[6] = payloadLength; //add the payload length to the packet
   if(payloadLength != 0x00){
      for(a = 0; a < payloadLength; a++){
         packet[a + 7] = *(packetPayload + a);   //add the payload to the packet here
   packet[payloadLength + 7] = DELIM;        //add the delimeter to the end of the packet
   for (a=0;a < (8 + payloadLength) ;a++){             //send the packet data
      bputc(packet[a]);
// Sending data
void sendData(int8 envTemp, int8 packetType, int8 *packet){
   int8 payloadLength = 0x00;   //set the payload length
   int8 a;
   packetPayload = (int8 *)calloc(4, sizeof(int8)); //allocate memory for the packet payload
   if(AC_State){
      *(packetPayload + 0) = ACStateON;     //AC is in on state
      payloadLength++;
   } else {
      *(packetPayload + 0) = ACStateOFF;     //AC is in off state
      payloadLength++;
   *(packetPayload + 1) = envTemp;       //here temperature values sholud be assigned
   payloadLength++;
   //payload length should be an even number
   for(a = 0; a < payloadLength; (a += 2)){
      payloadEncipher(32, (packetPayload + a));    //encrypt the packet payload here
   if(packetType == 0x03){
      createPacket(0x03, payLoadLength, packet);    //send data packet
   else if(packetType == 0x04){
      createPacket(0x04, payLoadLength, packet);    //send emergency data packet
   free(packetPayload); //free the memory, allocated for the packet payload
Kushan Sharma
mlkushan@gmail.com
