...12F683: ADC working at 8 bit instead of 10 bits
PICman
PostPosted: Thu Jan 15, 2009 6:14 pm     Reply with quote
Hi...
I'm beginning with the ADC in a PIC12F683...
Simplest design: One input and printout on serial port @ 9600,8,N,1
I put in a 20k trimpot between Vss and Vdd with wiper at pin 7 (An0) to test my setup with a screwdriver.
My bug is that i only get 8 bits ! The printout varies between 0x0000 and 0x00FF. 10 bits shall give me 0x0000 to 0x03FF.
I know, this is a newbie problem and i don't like to look as an annoying person, but i've read the CCS manual and the 12F683.h header and didn't find anything about the ADC resolution, and with a int16 variable for ADC output, it should give me a 10bit value (the 12F683 has a 10 bit ADC and i succedded in making the PWM work at 10 bits)
One last thing.... The manual (page 100) talks about an ADC_DONE interruption, but the compiler doesn't recognize it. Is there a way to initiate an interruption when the ADC has done it's work or is it better to simply add a delay after the "value=Read_ADC(ADC_START_AND_READ);" instruction ?
Thanks for your help !
//                     _________  _________                            //
//                  __|         \/         |__                         //
//             +5V |__|Vdd              Vss|__| Masse                  //
//                  __|                    |__                         //
//     8.0000 MHz  |__|Ra5      Ra0/ICSPDAT|__| EntrĂ©e analogue (0)    //
//                  __|                    |__                         //
// Sortie 9600bps  |__|Ra4      Ra1/ICSPCLK|__|                        //
//                  __|    ____            |__                         //
//  +5V-/\/\-------|__|Ra3/MCLR/Vpp     Ra2|__|                        //
//      47k           |____________________|                           //
//  ADC: Premiers essais en ADC                                        //
// ADC2: EC_IO @  8.0000 MHz                                           //
#include <12F683.h>
#FUSES WDT                      // Watch Dog Timer active
#FUSES EC_IO                    // External Osc with I/O
#FUSES NOCPD                    // No EE protection
#FUSES NOPROTECT                // Code not protected from reading
#FUSES NOMCLR                   // No Master Clear on pin 4.
#FUSES PUT                      // Power Up Timer
#FUSES BROWNOUT                 // Reset when brownout detected
#FUSES IESO                     // Internal External Switch Over mode enabled
#FUSES FCMEN                    // Fail-safe clock monitor enabled
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_A4,rcv=PIN_A3,bits=8) // 9600,8,N 1
   int16 value;
   setup_port_a(sAN0);
   setup_adc(ADC_CLOCK_DIV_32);
   set_adc_channel(0); // Lire An0 (broche 7)
   do
         delay_ms(50);
         value=Read_ADC(ADC_START_AND_READ); //Lire Vin
         printf("\n\r Value=%4lX",value); // Affiche "value" en HEX
         restart_wdt(); // Woof !
   }while (TRUE);
PostPosted: Thu Jan 15, 2009 6:23 pm     Reply with quote
https://www.ccsinfo.com/forum/viewtopic.php?p=2073
PICman
PostPosted: Thu Jan 15, 2009 6:39 pm     Reply with quote
Thanks a lot for this so fast response !
