SPI Can't work of PIC18452
sindyvirgo
PostPosted: Thu Jan 15, 2009 1:16 am     Reply with quote
Experiment board : Microchip App001
I use SPI to write PIC and EEPROM (25LC160A)
Could you tell me how I should do ?
I have tried the following ways ...
#define SPI_MODE_1  (SPI_L_TO_H)
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_MODE_1|SPI_CLK_DIV_16);
//write to spi
output_low(CS);
SPI_write(0x06);
SPI_write(0x02);
spi_write(0x00);
spi_write(0x10);
spi_write('A');
delay_us(100);
output_high(CS);
//read from spi
output_low(pin_a5);
SPI_write(0x03);
spi_write(0x00);
spi_write(0x10);
SPI_Msg = SPI_read();
output_high(pin_a5);
if(spi_data_is_in())
   printf("%c",SPI_Msg);
My procedure can't work, please help me !!
PostPosted: Thu Jan 15, 2009 2:59 am     Reply with quote
You problem is that you need a driver for the 25LC160A.
You have SPI mode 1 selected, but the data sheet says it uses
modes 0 or 3. Look at the timing diagram on page 5 on the left side:
FIGURE 1-2: SERIAL INPUT TIMING
It gives those two modes (in binary notation). 25LC160A data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/21807D.pdf
Here's an example of a hardware SPI driver for the 25LC640.
I think it will work for the 25LC160A. Try it.
http://www.ccsinfo.com/forum/viewtopic.php?t=28199&start=1
