input problem
shoyur
input problem
PostPosted: Wed Jan 14, 2009 11:35 pm     Reply with quote
Weird problem -­>
a 16F876A, PCW 4.057 and a very simple circuit with 2 pushbuttons...
#include <16F876A.h>
#fuses NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD
#include <LCD420.c>
   int16 i;
      lcd_init();
      lcd_putc("\f 1 \n  2 \n 3 \n 4 ");
      while(1) {
         lcd_gotoxy(1,2);   //// 2e ligne
      if (input(PIN_C7)) { lcd_putc("BOUTON #2 (C7) : OUI"); }
      else { lcd_putc("BOUTON #2 (C7) : NON"); }
      lcd_gotoxy(1,3);   //// 3e ligne
      if (input(PIN_C6)) { lcd_putc("BOUTON #1 (C6) : OUI"); }
      else { lcd_putc("BOUTON #1 (C6) : NON"); }
and now I plug in and it says NON and NON but sometimes a OUI appear for some random seconds, if I push buttons, it works half the time, and most of the time the both OUI stay OUI by themself and come back to NON when they want, maybe 3 to 15 sec later .... the problem can't be my buttons, I use jumpers. Its a clean board, new and well used 20mhz oscillator, and stable constant 5.062V, and all wires not touching themself or wrecked.
I tried putting a i++ in my loop and lcd_putc the i to see if it increase each 500ms, it works, so its not a defect clocking ...
thank you Confused
PostPosted: Wed Jan 14, 2009 11:55 pm     Reply with quote
Describe your pushbutton circuits.
You should have a pull-up resistor (4.7K or 10K) on pins C6 and C7.
Then one side of each push button switch should go to pin C6 or C7.
The other side of each switch should go to ground.
