problem with int0 and adc routine
nehallove
PostPosted: Mon Jan 12, 2009 5:23 pm     Reply with quote
Hi guys,
I am using pic18f25k20.
I have following adc routine.
setup_adc_ports(sAN1);    //|VSS_VDD); // setup port RA1/AN1 as an analog
////setup_adc(ADC_CLOCK_INTERNAL);  //|ADC_TAD_MUL_0);
set_adc_channel(1);             // setup channel 8 for battery reading
adc_value = read_adc();
setup_adc_ports(NO_ANALOGS|VSS_VDD); // set back the ports in digital mode
setup_adc(ADC_OFF);
now whenever i execute this routine my external interrupt 0 become disabled. i check and tested a code and i found out "setup_adc(ADC_OFF)" causing interrupt 0 not to work.
if i use "setup_adc(ADC_CLOCK_INTERNAL)" then interrupt works.
my external interrupt routine is:
disable_interrupts(INT_EXT); //! don't reenable in ISR
clear_interrupt(INT_EXT);
//! timer 0 setup for debouncing time
clear_interrupt(INT_RTCC); //! enable debouncing timer0 interrupt
enable_interrupts(INT_RTCC);
set_timer0(TIMERVALUE);
i am enabling interrupt in timer routine.
regards:
nehal
nehal
PostPosted: Mon Jan 12, 2009 5:51 pm     Reply with quote
You need to setup the ADC ports before you read the ADC.
The ADC needs to be enabled before you read it.
See this post which shows how to setup the ADC. It shows the
correct order for the setup statements.
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
nehallove
PostPosted: Tue Jan 13, 2009 2:03 pm     Reply with quote
it turns out if i use ADC_CLOCK_DIV_8 for setting up adc it works but if use ADC_CLOCK_INTERNAL then it is same problem. does anybody has any idea?
thanks you for a prompt reply PCM Programmer.
regards:
nehal
nehal
PostPosted: Tue Jan 13, 2009 2:15 pm     Reply with quote
Read the A/D section of the PIC data sheet. It says this about the
internal A/D clock:
When the device frequency is greater than 1 MHz, the FRC clock source
is only recommended if the conversion will be performed during Sleep.
Since you are almost certainly running the PIC at a frequency greater
than 1 MHz, the INTERNAL ADC clock is not recommended.
