LCD nokia clone + 16F877
Guest09
PostPosted: Mon Jan 12, 2009 1:48 pm     Reply with quote
Hi dear friends.
I'm reading this post
http://ccsinfo.com/forum/viewtopic.php?t=26461&highlight=nokia+6100
so i was thinking to give a try with some cheap nokia 6100 clone (sparkfun).
Does anyone knows how to connect such LCD to 16F877 ?
Can i convert the code for use with 16F877 ?
PostPosted: Mon Jan 12, 2009 5:27 pm     Reply with quote
The page on the Sparkfun site has lots of links to documents and code examples, even example code for a PIC16F87x written in CCS-C.
I've never seen an Electronics site with so much practical product info. What more do you want??? They even provide code for your processor!
I don't know you can do it. Wink
Guest09
PostPosted: Tue Jan 13, 2009 2:03 pm     Reply with quote
Embarassed Mr. Green
I know i can't Very Happy
I didn't buy this lcd yet because i got some old ones from nokia 3200.
I pull them out.
My problem is more on hardware side - for now :-).
There are few examples with picmicro and 6100 but I can't find some "how to connect" tutorial for 3200 LCD. I found pinouts but heeeee ?
2   Gnd
3   MBus
4   Vpp
7   FBus Rx
8   FBus Tx
A   Vbat+
B   BSI
C   BTemp
Which pins on 16F877 should I use ?
PICoHolic
PostPosted: Wed Jan 14, 2009 2:24 am     Reply with quote
Example PIC 16F87x code for CCS Compiler:
http://www.sparkfun.com/datasheets/LCD/nokial6100_ccs_c.zip
PostPosted: Wed Jan 14, 2009 7:41 am     Reply with quote
OK on the 16f877 side but what about LCD side ?
What pins of the LCD should i use, what is what.
Thank you for your help!.
LCD_RESET PIN_C0
LCD_CS PIN_C1
SPI_CLK PIN_C3
SPI_DI PIN_C4 //unused
SPI_DO PIN_C5
2 Gnd
3 MBus
4 Vpp
7 FBus Rx
8 FBus Tx
A Vbat+
B BSI
C BTemp
dyeatman
PostPosted: Wed Jan 14, 2009 8:02 am     Reply with quote
The pinout is at the bottom of the page referenced by the first link you gave
http://www.sparkfun.com/commerce/product_info.php?products_id=569
    Pin breakout from source code:
    LCD_CS PIN_C1
    SPI_CLK PIN_C3
    SPI_DI PIN_C4 //unused (means you don't connect this one)
    SPI_DO PIN_C5
    From Sparkfun Pinout List:
    1. VCC-Digital (3.3V)
    2. RESET -------> LCD_RESET PIN_C0
    3. SDATA -------> SPI_DO PIN_C5
    4. SCK ----------> SPI_CLK PIN_C3
    5. CS ------------> LCD_CS PIN_C1
    6. VCC-Display (3.3V)
    7. N/C
    8. GND
    9. LED GND
    10. LED V+ (6-7V)
Looks pretty straightforward to me.
PostPosted: Wed Jan 14, 2009 8:21 am     Reply with quote
Thank you dyeatman but i didn't buy this LCD yet.
Instead of this i found some old LCD's from cellular phones ( to save the environment :-) )
Sony ericsson t290
Sony ericsson t100
Nokia 3200
The pinouts that i posted are from nokia 3200.
2 Gnd
3 MBus ---
4 Vpp ---
7 FBus Rx ---
8 FBus Tx ---
A Vbat+
B BSI ---
C BTemp ---
I dont know what is FBus RX and TX, BSI, BTemp.
In cca 2 hours i will send photos and pinouts of other two model's, so please be so kind and help me out.
dyeatman
PostPosted: Wed Jan 14, 2009 9:30 pm     Reply with quote
What you are lisiting is the pinout of the phone not the LCD.
From what i can determine the LCD is the same one as the 6100 and has the pinout I listed earlier.
A couple of links with more info. The second one has a hookup schematic for the LCD to a PIC.
www.quantumtorque.com/content/view/32/37/
www.forum.lcdinfo.com/viewtopic.php?t=586&postdays=0&postorder=asc&highlight=3200&start=75
PostPosted: Thu Jan 15, 2009 1:37 am     Reply with quote
- aaaaaaaa, damn.
OK, i gonna try to connect it and see what will happen :-)
Thank you for your reply's !
PostPosted: Thu Jan 15, 2009 1:58 am     Reply with quote
Sorry, one more thing.
Do you know if there is some compatibile CCS driver for sony ericcson T100 LCD. I search for on the forum but whitout succes.
I am going to search for hardware connection.
Thank you.
TYSON
stuck, NOKIA 6100 knock off LCD to PIC18F4580
PostPosted: Fri Jan 23, 2009 4:03 pm     Reply with quote
Can anyone help?
I just purchased a nokia 6100 lcd last week from sparkfun and have modified code for my 18f4580 chipset, I have modified from the example provided with lcd breakaway board Marcus Russell wrote.
After modifiy code I have been abler been troubleshooting for several days now with no luck. All I have is a the backlight working with blue screen and I have verified that the clock signal from my pic looks correct.
Could someone take a look at my code to see if I am missing something?
I know its alot to ask.....
Also I have verified that the driver/controller is an EPSON S1D15G10
//// Marcus Russell, modified by Tyson
//// Russell Evolutions Inc.
//// Nokia 6100 LCD with Epson S1D15G10 Controller
////  sample initialization program for PIC16LF872 in CCS C  3-14-07
//// Based on Spark Fun Electronics Code by Owen Osborn 1-22-05
////   with thanks to David Carne of SFE for DISCTL help
////   and user 'Ttelmah' from CCS C forum for SSPEN bit idea for 9-bit hardware SPI
//// You are free to use this code for any purpose.
//// START OF HEADER FILE ////
//#include <16F872.h>
#include <18f4580.h>
//#device adc=8
#FUSES HS                       //Crystal Osc (20Mhz)
#FUSES PUT                      //Power Up Timer
#FUSES NOBROWNOUT               //Don't Reset when brownout detected
#device ICD=TRUE
//#fuses HS,NOWDT,NOPROTECT,NOLVP
//#use delay(clock=20000000)
#define LCD_RESET   PIN_D4
#define LCD_CS      PIN_D5
#define SPI_CLK     PIN_D6
#define SPI_DI      PIN_D1 //unused
#define SPI_DO      PIN_D7
#define REDLED PIN_E0
#define GRNLED PIN_E2
#define BLULED PIN_A2
#bit SSPEN = 0x14.5   // bit to turn on/off hardware SPI
// Epson S1D15G10 Command Set
#define DISON       0xaf
#define DISOFF      0xae
#define DISNOR      0xa6
#define DISINV      0xa7
#define SLPIN       0x95
#define SLPOUT      0x94
#define COMSCN      0xbb
#define DISCTL      0xca
#define PASET       0x75
#define CASET       0x15
#define DATCTL      0xbc
#define RGBSET8     0xce
#define RAMWR       0x5c
#define RAMRD       0x5d
#define PTLIN       0xa8
#define PTLOUT      0xa9
#define RMWIN       0xe0
#define RMWOUT      0xee
#define ASCSET      0xaa
#define SCSTART     0xab
#define OSCON       0xd1
#define OSCOFF      0xd2
#define PWRCTR      0x20
#define VOLCTR      0x81
#define VOLUP       0xd6
#define VOLDOWN     0xd7
#define TMPGRD      0x82
#define EPCTIN      0xcd
#define EPCOUT      0xcc
#define EPMWR       0xfc
#define EPMRD       0xfd
#define EPSRRD1     0x7c
#define EPSRRD2     0x7d
#define NOP         0x25
#define ENDPAGE     132
#define ENDCOL      130
////  START OF MAIN .C SOURCE FILE ////
//#include "<path to .h file cut from above>"
#use fast_io(C)
void pset(unsigned char color, unsigned char x, unsigned char y);
void spi_command(int);
void spi_data(int);
   int16 i,x;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED, 0, 1);
   set_tris_c(0x00);   // all outputs, can change to mask only hardware SPI bits if needed
   set_tris_d(0x00);
   // reset display
   for (x=0;x<10;x++){
   output_low (SPI_CLK);
   output_low (SPI_DO);
   output_high (LCD_CS);
   output_low (LCD_RESET);
   output_high (LCD_RESET);
   //init'd, now drop CS to send commands/data and raise when finished
    spi_command(DISCTL);  // display control
    spi_data(0x0C);      // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
    spi_data(0x20);      // 32 = (128/4)-1 (round up) number of display lines for scanning
    spi_data(0x0C);      // 12 = 1100 - number of lines to be inversely highlighted
    spi_data(0x00);
    spi_command(COMSCN);  // common scanning direction
    spi_data(0x01);
    // 0 0 0 =   1 -> 80   81 -> 160
    // 0 0 1 =   1 -> 80   81 <- 160
    // 0 1 0 =   1 <- 80   81 -> 160
    // 0 1 1 =   1 <- 80   81 <- 160
    spi_command(OSCON);  // internal oscialltor ON
    spi_command(SLPOUT);  // sleep out
    spi_command(VOLCTR);  // electronic volume, this is the contrast/brightness
    spi_data(0x23);   // volume (contrast) setting - fine tuning
    spi_data(0x03);   // internal resistor ratio - coarse adjustment
    spi_command(PWRCTR);  // power ctrl
    spi_data(0x0f);      //everything on, no external reference resistors
    spi_command(DISINV);  // invert display mode
    spi_command(DATCTL);  // data control
    spi_data(0x00);   // normal display of page/column address, page scan direction
    spi_data(0x00);   // normal RGB arrangement
    spi_data(0x01);   // 8-bit grayscale
    spi_command(RGBSET8);   // setup 8-bit color lookup table  [RRRGGGBB]
    //RED
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    // GREEN
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    //BLUE
    spi_data(0);
    spi_data(4);
    spi_data(9);
    spi_data(15);
    spi_command(NOP);  // nop
  pset(0b11100000, 0, 0); // red pixel top left (also sets start of bulk write, see pset routine)
  for (i = 1; i <= 16900; i++) {  // 130x130 = 16900
      spi_data(0b11100000);   // fill screen red
  spi_command(DISON);   // display on
  //while (1) {  // main program loop.  just blinks A0 to show chip is running
  for (i=0;i<3;i++){
      output_toggle(REDLED);
      output_toggle(GRNLED);
      output_toggle(BLULED);
      delay_ms(100);}
   output_high(REDLED);
void pset(unsigned char color, unsigned char x, unsigned char y){
//  sets the starting page(row) and column (x & y) coordinates in ram,
//  then writes the colour to display memory.  The ending x & y are left
//  maxed out so one can continue sending colour data bytes to the 'open'
//  RAMWR command to fill further memory.  issuing any other command
//  finishes RAMWR.
  x += 2;                  // for some reason starts at 2
  spi_command(PASET);   // page start/end ram
  spi_data(x);
  spi_data(ENDPAGE);
  spi_command(CASET);   // column start/end ram
  spi_data(y);
  spi_data(ENDCOL);
  spi_command(RAMWR);    // write
  spi_data(color);
void spi_command(int dat){
   output_low(LCD_CS);      // enable chip
   SSPEN = 0;               // shut off hardware SPI allowing direct access to SPI in/out pins
   output_low (SPI_DO);     // output low on data out (9th bit low = command)
   output_high (SPI_CLK);
   delay_cycles(1);         // send clock pulse
   SSPEN=1;                 // turn hardware SPI back on
   spi_write(dat);          // make PIC do the work for the command byte
   output_high(LCD_CS);     // disable
void spi_data(int dat){
   SSPEN = 0;               // turn off hardware SPI allowing us direct access to SPI in/out pins
   output_high (SPI_DO);    // output high on data out (9th bit high = data)
   spi_write(dat);          // make PIC do the work for the data byte
PostPosted: Fri Jan 23, 2009 4:15 pm     Reply with quote
Download the 18F4580 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39637c.pdf
Look at this page on page 80 in the Acrobat Reader. It shows that
the SSPEN bit is in the SSPCON1 register.
TABLE 5-2: REGISTER FILE SUMMARY (PIC18F2480/2580/4480/4580) (CONTINUED)
Now look at this table on page 73 of the data sheet in the Acrobat reader.
What is the address of the SSPCON1 register for the 18F4580 ?
Find the correct address and modify the value shown in bold above.
TABLE 5-1: SPECIAL FUNCTION REGISTER MAP FOR
PIC18F2480/2580/4480/4580 DEVICES
hobiadami
View user's profile Send private message Visit poster's website ICQ Number
Nokia 6100 LCD
PostPosted: Thu Jan 27, 2011 12:29 pm     Reply with quote
I'll try to interface the Nokia 6100 LCD to a pic 16F877a by using the CCS C software given at Sparkfun site.
Below are the images of the LCD that I found at a local cell phone spares shop for around 3.5$ each. It has got a green pcb and connecting wires so it should have an Epson controller. But on a page of LCD photos, an LCD similar to mine was listed as having the phillips controller. Is there a way to be sure? or can anyone verify it by its photos? Well I could have compiled the code and tested on the chip and LCD but asking on the forum might save some of my hair from going white I guess. Any help is appreciated. Thanks in advance.
http://img8.imageshack.us/i/dscn0005g.jpg/
http://img13.imageshack.us/i/dscn0007v.jpg/
http://img375.imageshack.us/i/dscn0006d.jpg/
