USART - changing to odd parity
mshearer
PostPosted: Mon Jan 12, 2009 4:38 am     Reply with quote
Hi, I have a UART connection with working transmit/recieve.
However i need to change the parity to odd. Should this be a simple case of changing
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8
to
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=O, bits=8
then adjusting the settings in whatever terminal application?
thanks for any help given,
matt
mshearer
PostPosted: Mon Jan 12, 2009 5:19 am     Reply with quote
not to worry, seem to have it fixed.
I didn't have the TX9 and RX9 bits enabled for 9th bit use.
matt
