18F4550 and int osc hangs with getc
bertocar1974
PostPosted: Sun Jan 11, 2009 4:28 am     Reply with quote
I'm trying to convert a project that i have developed for mikroc and that runs correctly in my board.
The problem i have is that getc() and kbhit() locks the execution.
I've tryed with interrupts too, but nothing changes.
Putc() sends correctly data.
The project runs perfectly with a mikroc version, so cannot be an hardware problem.
The oscillator is internal, 8Mhz.
This is the code:
(main.h)
#include <18F4550.h>
#FUSES INTHS                    //Internal Oscillator, HS used by
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOMCLR                     //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES PLL12                    //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV1                  //System Clock by 4
#FUSES USBDIV                   //USB clock source comes from PLL divide by 2
#FUSES NOVREGEN                 //USB voltage regulator enabled
#FUSES ICPRT                    //ICPRT enabled
#use delay(clock=8000000)
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
#use i2c(Master,Slow,I2C1)
(main.c)
#include "main.h"
#include <string.h>
#define VERSION   "1.3.1"
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
 char ch;
 set_tris_a(0b00001110);
 set_tris_b(0b10010100);
 set_tris_c(0b11000100);
 set_tris_d(0b00010000);
 set_tris_e(0b00000000);
 setup_spi(FALSE);
 setup_adc_ports(AN0_TO_AN2|VSS_VDD);
 setup_psp(PSP_DISABLED);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT);
 setup_timer_1(T1_DISABLED);
 disable_interrupts(GLOBAL);
 setup_vref(FALSE);
 enable_interrupts(INT_EXT2);
 enable_interrupts(INT_RDA);
 setup_oscillator(OSC_8MHZ|OSC_INTRC);
 putc('#');  // this is ok
 for (;;)
  if (kbhit())  // << stops running
   ch = getc();
   putc(ch);
Can someone help me about the code?
Thanks,
Alberto
FvM
PostPosted: Sun Jan 11, 2009 5:33 am     Reply with quote
The present code can't work, cause it enables interrupts without an interrupt service routine. This also doesn't make sense with any other C compiler, I suppose.
If global interrupts are disabled, this doesn't hurt, but then I don't see a reason for the observed behaviour.
bertocar1974
PostPosted: Sun Jan 11, 2009 8:23 am     Reply with quote
I have extracted a part of the project.
The other compiler version is different, obviously.
Commenting out the interrupt enable parts, (if you have observed there is global interrupt set to off) nothing changes.
Thank you.
Alberto
n-squared
PostPosted: Sun Jan 11, 2009 11:00 am     Reply with quote
Try commenting out the setup_oscillator() line.
My experience is that sometimes this function causes problems.
Every solution has a problem.
bertocar1974
PostPosted: Sun Jan 11, 2009 12:20 pm     Reply with quote
Thank you!
That is the problem, setting OSCCON manually resolved the problem.
Maybe a CCS bug?
Best regards,
Alberto
