rhaguiuda
Joined: 05 Sep 2007 Posts: 46 Location: Londrina - Brazil
2 PICs (8-bit), same size and program, different ROM usage? |
Posted: Thu Jan 08, 2009 5:31 am |
This is very strange to me.
My compiler version is: 4.057
I'm using a 16F628A in my project, but when the ROM usage hit 99% I changed to 16F870 just for testing ROM usage. The strange thing is ROM drop to 85%. (both PICs have 2kwords).
How is that possible if the only change I made in the code was internal to external oscillator?
I'v also checked the instruction set in both datasheet, and they're same!
So, same instruction set, both 8-bit, same program.. but one is 15% smaller??? How? _________________ Give a man a fish and you'll feed him for a day. Teach a man to fish, and you'll feed him for a lifetime. |
Posted: Thu Jan 08, 2009 12:06 pm |
What peripheral modules are you using ? They are on different pins
in these PICs. It's possible that on one PIC you are using a hardware
module, but in the other PIC you are using software emulation.
(i.e., CCS can do a hardware or software UART, depending on the pins
that are specified in the #use rs232() statement).
Also, the RAM layout is different. There might be a different allocation
of variables, requiring more bank select instructions.
However, 15% does seem excessive. If you want to know for sure,
you will have to do a side-by-side comparison of the .LST files. |
rhaguiuda
Posted: Thu Jan 08, 2009 12:14 pm |
Thanks for replying PCM.
When I put a receive/transmit PIN that is different from PIC's TX/RX pins, the compiler automatically creates a software USART?
Anyway, I don't believe this is the problem, because in 16F628A the pins were correctly assigned to TX/RX pins. If with the 16F870 the compiler was generating a software USART, than the code would be larger, not smaller, isn't?
Well, about taking a look at both .lst files, I have no time to make a side by side comparison, so I took another PIC and move on with my project.
Thanks very much. _________________ Give a man a fish and you'll feed him for a day. Teach a man to fish, and you'll feed him for a lifetime. |
asmallri
Posted: Thu Jan 08, 2009 12:39 pm |
Quote: | Give a man a fish and you'll feed him for a day. Teach a man to fish, and you'll feed him for a lifetime. |
If he does not have a fishing license then the state will feed him for free - some restrictions, such as liberty and choice of clothing, apply. _________________ Regards, Andrew
SherpaDoug
Posted: Thu Jan 08, 2009 3:03 pm |
I prefer "Build a man a fire and he is warm for a day. Set a man on fire and he is warm for the rest of his life." Call it January humor.... _________________ The search for better is endless. Instead simply find very good and get the job done. |
