Help! Code in Timer int now working?
jaikumar
PostPosted: Thu Jan 08, 2009 7:22 am     Reply with quote
Why is this not working?
#INT_TIMER1
void clock_isr()
if (pcComm == 0x00)
 if ((dataCount == 22) && (RcvData[18] == 0x39)) Status = 'F';
 else if ((dataCount == 20) && (RcvData[18] == 0x3a)) Status = 'N';
 else if ((dataCount == 13) && (RcvData[11] == 0x33)) Status = 'T';
if ((PcComm == 0x01) && (dataCount == 20) && (RcvData[18] == 0x31)) printf(usb_cdc_putc, "Ok.");
#INT_RDA
void rda_isr()
 disable_interrupts (INT_TIMER1);
 RcvData[dataCount++] = getchar();
 enable_interrupts (INT_TIMER1);
Actually it works if i either have this code
if (pcComm == 0x00)
or
this code
but if i have both of them as shown above it does not work. ANY IDEAS?
Thanks and Regards,
Jai
dyeatman
PostPosted: Thu Jan 08, 2009 7:44 am     Reply with quote
When you ask a question please be clear. What do you mean by "not working"?
Without knowing your answer I can already see a potential problem where you trying to PRINTF inside the timer routine. DOZENS of times we have said here to get out of an interrupt as quickly as possble. While in the interrupt routine do not transmit or print anything. It is even advised to avoid floatng point.
Why are you disablng the Timer interrupt in INT_RDA? If a Timer interrupt comes in during INT_RDA it won't be serviced until INT_RDA is completed.
