usb_cdc_getc() returns 0 on PIC18F2450
capnmatt
PostPosted: Wed Jan 07, 2009 11:45 pm     Reply with quote
HELP!!!
I am trying to get the USB port working on my PIC 18F2450. My code (posted Below) enumerates and the PC side seems happy.
I've written a VB2008 exe that sends one character to the virtual comm port then waits for one character to be returned.
My Pic code receives the one character and sends it right back out.
For some reason, the usb_cdc_getc() funciton seems to only return 0. The transmission from the PIC seems to work. I can hard code it to send integers from 0 to 255 and my VB code reads it okay.
Any thoughts from the community?
#include <18F2450.h>
#device adc=8
#fuses ECPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL1,CPUDIV4,VREGEN
#use delay(clock=16000000)
#include <usb_cdc.h>
#define led1 pin_c6
#define led2 pin_c7
#define LED_ON output_high
#define LED_OFF output_low
int8 DATA_RX;
void main(){
LED_OFF(led1);
LED_OFF(led2);
usb_init();
while (true) {
if (usb_enumerated()){
led_on(led1);
if(usb_cdc_kbhit()){
DATA_RX = usb_cdc_getc();
usb_cdc_putc(DATA_RX);
PostPosted: Thu Jan 08, 2009 12:14 am     Reply with quote
usb_task() is missing - at least in the shown code. You can use a software USB monitor and check, if the intended data bytes are actually transmitted to the device.
Gendrick
View user's profile Send private message AIM Address Yahoo Messenger ICQ Number
VB code
PostPosted: Sat Jan 10, 2009 11:54 am     Reply with quote
Hi capnmatt, where can I find a VB code for USB port with PIC, thanks , my email is gendrick@cantv.net
