SHT71(Temperature & Humidity Sensor) Code problem
tarmimi
PostPosted: Wed Jan 07, 2009 10:28 pm     Reply with quote
Hello everyone. I would like to ask about communication between the SHT71 sensor and PIC18F6722.
I found a sample code from the forum but not CCS and I have edited the code for CCS application. The problem is I cant get the value of temperature and humidity to display on hyperterminal. When I reset the PIC, the value of temperature and humidity appear but not correct.
// Example of user space C program to read a humidity and temperature
// sensor Sensirion SHT71 (http://www.acmesystems.it/?id=89)
#include <18f6722.h>
//#include<intrins.h.>
#include<math.h>
#include<stdio.h.>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, stream=PC)
// SHT71 sensor define
#define CLOCK_BIT         PIN_B1
#define DATA_BIT           PIN_B0
// Macro to set the data line direction
//#define DATA_LINE_IN        gpiosetdir(PORTG,DIRIN,DATA_BIT)
//#define DATA_LINE_OUT     gpiosetdir(PORTG,DIROUT,DATA_BIT)
//#define DATA_LINE_IN        set_tris_c(0x01)
//#define DATA_LINE_OUT     set_tris_c(0x00)
//#define DATA_LINE_LOW     0
//#define DATA_LINE_HIGH    1
//#define DATA_LINE_READ    gpiogetbits(PORTG,DATA_BIT)?(1):(0)
//#define DATA_LINE_READ    input_state(PIN_C0)
//#define CLOCK_LINE_LOW    0
//#define CLOCK_LINE_HIGH   1
#define CMD_READ_TEMP     0x03
#define CMD_READ_HUM      0x05
// Send the start sequence
void SendStart(void) {
  //DATA_LINE_OUT;
  set_tris_b(0x00);
  output_high(DATA_BIT);
  output_low(CLOCK_BIT);
  delay_cycles(1);
  output_high(CLOCK_BIT);
  delay_cycles(1);
  output_low(DATA_BIT);
  delay_cycles(1);
  delay_cycles(1);
  delay_cycles(1);
  delay_cycles(1);
  //DATA_LINE_IN;
  set_tris_b(0x01);
// Sensor reset
void SendReset(void) {
  int i;
  for (i=0;i<12;i++) {
    delay_cycles(1);
  SendStart();
// Send a byte to the sensor
int SendByte(unsigned char value) {
    int i;
  //DATA_LINE_OUT;
  set_tris_b(0x00);
  for (i=0x80;i>0;i/=2) {
    if (i & value)
     delay_cycles(1);
  //DATA_LINE_IN;
  set_tris_b(0x01);
  return 1;
// Read a byte from the sensor
// withack
//   1 = send the ACK
//   0 = don't send the ACK
char ReadByte(int withack) {
  char val=0;
  int i;
  int x;
  //DATA_LINE_IN;
  set_tris_b(0x01);
  x=input_state(DATA_BIT);
    if (x) val = (val| i);
  if (withack) {
    // Acknowledge del byte
    //DATA_LINE_OUT;
    set_tris_b(0x00);
    //DATA_LINE_IN;
    //set_tris_b(0x01);
  } else {
    // Senza acknowledge
    //DATA_LINE_OUT;
    set_tris_b(0x00);
    //DATA_LINE_IN;
    set_tris_b(0x01);
  return val;
// Read the temperature
int ReadTemperature(void){
  char Lsb,Msb,Chk;
  int z;
  SendStart();
  z=input_state(DATA_BIT);
  if (!SendByte(CMD_READ_TEMP)) return 0;
  while(z);
  Msb=ReadByte(1);
  Lsb=ReadByte(1);
  Chk=ReadByte(0);
  return ((Msb<<8)+Lsb);
// Read the humidity
int ReadHumidity(void) {
  char Lsb,Msb,Chk;
  int y;
  SendStart();
  y=input_state(DATA_BIT);
  if (!SendByte(CMD_READ_HUM)) return 0;
  while(y);
  Msb=ReadByte(1);
  Lsb=ReadByte(1);
  Chk=ReadByte(0);
// main code
void main(void) {
  float real_humidity;
  float real_temperature;
  int soh;
  int sot;
  SendReset();
  soh=ReadHumidity();
  sot=ReadTemperature();
  real_humidity= -4 + 0.0405*soh + -2.8E-6;
  real_temperature = -39.66 + 0.01*sot;
   printf ("Humidity   : %.2f %%\n",real_humidity);
   printf ("Temperature: %.2f C\n",real_temperature);
If someone does have working sample code for this SHT71 sensor hopefully will help me. Thanks.
ECACE
PostPosted: Wed Jan 07, 2009 10:57 pm     Reply with quote
Search the CCS forum and there is a driver in the code section.
http://www.ccsinfo.com/forum/viewtopic.php?t=28564&highlight=sht71
A HW Engineer 'trying' to do SW !!! Run!!!
tarmimi
thanks..
PostPosted: Thu Jan 08, 2009 1:47 am     Reply with quote
the driver working perfectly...now takes time for me to understand the code...anyway thanks for the help...really appreciate that help cause i've been trying since last 2 weeks..only needs to understand a little bit and a bit modification on code and now my my SHT71 working perfectly...the value displayed on hyperteminal
