SORTED: Please Help a Programming Newbie - 16F873A
Razo
PostPosted: Fri Jan 02, 2009 8:31 pm     Reply with quote
Right. I'm new to the micro controller game.
I've been playing with making simple programs with 12F683's which have an internal oscillator and they have been going fine Smile
But i need more I/O pins so I got me a few 16F873A's as they seem to be easy to get hold of, have the I/O pins I need and have plenty of stuff about them out there on the net.
The problem is I can't get any code to run on them :( as 16F873A's don't have an internal oscillator I also got me some 20Mhz Ceramic Resonator's (ZTT design - as I read these work) to run them. But I can't seem to get the things to work :(
For example I have the following code
#include <16F873A.H>
#use delay(oscillator=20M)
#fuses  NOLVP
      output_bit(PIN_A0,0);
      output_bit(PIN_A0,1);
I've used multiple variations of the same code but still can't seem to get the thing to work.
I have the chip wired like this:
Pin 19 - VSS - to ground
Pin 20 - VDD - to +V5 (provided by a voltage regualator)
Pin 9 - OSC1 - To the left pin of the Ceramic Resonator
Pin 10 - OSC2 - To the right pin of the Ceramic Resonator
(middle pin of the Ceramic Resonator to ground)
Pin 2 - A0 - to the Anode of a LED
(cathode of the LED to ground thou a resistor)
once i power the chip nothing happens, I don't have access to any special tools to see whats happening inside the chip - but if i use the same code on a 12F683 it works fine
#include <12F683.H>
#use delay(clock = 20000000)
While(1)
      output_high(PIN_A0);
      output_low(PIN_A0);
I'm guessing I'm doing something wrong with the oscillator and I'm hoping one of you can point me in the right direction... if you need anymore info or anything just post back
Thanks Smile
OH BTW: I'm using the latest version of the compiler Smile
EDIT: Found the info i needed (I swear i searched and found nothing)
http://www.ccsinfo.com/forum/viewtopic.php?t=37157
i was using the wrong #fuses :S
changed the top to
#fuses HS,NOWDT,NOLVP
#use delay(clock=20M)
All was well Smile and added a voltage to the reset pin as the code was only running for a short time before stopping (I had tried running the reset pin high but wasn't getting anywhere)
ECACE
PostPosted: Fri Jan 02, 2009 10:50 pm     Reply with quote
What are you doing with the MCLR pin? You should have it pulled up to Vcc via a resistor, say 4.7K.
A HW Engineer 'trying' to do SW !!! Run!!!
Razo
PostPosted: Sat Jan 03, 2009 10:13 am     Reply with quote
Thats exactly how i'm pulling it up Smile
