mrf24j40 and pic16f877a
Posted: Fri Jan 02, 2009 5:56 am
hello friends
i would like to do a zigbee implimentation project using mrf24j40 as tranceiver and pic16f877a as host controller, is it possible to impliment zigbee protocol using thease two ic s,any body can give me the basic steps to start this project..iam littile bit confused how to start this project......pls help me to do this or if it is not posible pls give me a simple way to impliment zigbee protocol using 8 bit picmicrocontroller? thaanks in advaance.......... _________________ nn
Posted: Fri Jan 02, 2009 8:42 am
You should do some searching in this forum since the ZIGBEE topic has been brought up previously. Apparently not many people in this forum have worked with it but someone may be able to help.
The Microchip AN1192 App Note, driver source code and lots of other info is posted here:
