Int32 to string conversion; fastest itoa
Torello
PostPosted: Fri Jan 02, 2009 2:57 am     Reply with quote
First, best wishes to everybody on this forum. A C-full 2009!
Tweaking my application to the minimum energy consumption (thus also execution speed of a task), I found out that sprintf 4 int32 values take up about 92 ms (18LF4620 @4Mhz)! Quite shocked!
Replaced the sprintf with the use of ccs-itoa, but that did not make any difference; probably sprintf uses ccs-itoa. Then took a look at the standard-c itoa. It is using the % (mod) operator heavily. The code looks very resources efficient. I've come up with an replacement below. Uses probably more recourses, but It does the same 4 int32 in 10ms!. So nine times faster. Or 90% discount on energy consumption. Heh, thats worth while spending on a little more bytes.
Can we make this function still faster? Or has somebody an other, faster routine to share?
Regards,
Edwin
// Function converts int32 to signed decimal string
// returns pointer to the '/0' ended string. (handy for formatting more values)
char *i32toa(int32 n, char *s) {
  int8 i,j;                    //decade counter
  int8 idx=0;                  //string index
  int32 const Div[10] = {      //decades table
    1000000000L,100000000L,10000000L,1000000L
    100000L,10000L,1000L,100L,10L,1};
  int32 b;                     //i32 to hold table read
  int fdd;                     //first digit detect (suppress leading zero function)
  fdd=0;                       //clear detection
  if (bit_test(n,31)) {        //T: n=negative
    n=(~n)+1;                  //convert to positive
    s[0]='-';                  //mark the negative number
    idx++;
  for (i=0; i<10;i++) {        //do all the decades, start with biggest
    j=0;                       //clear the decimal digit counter
    b=Div[i];                  //read the table once;
    while (n>=b) {             //T: "left-over" still bigger then decade; substr. and count
      j++;
      n-=b;
    if ((j)||(fdd)) {          //T: decade count!=0 or first digit has been detected
      fdd=1;
      s[idx++]='0'+j;          //..then add the decade count
  if (!fdd) s[idx++]='0';      //dont suppress zero when n==0!
  s[idx]=0;                    //end the string
  return(s+idx);               //return last written pointer
//=== code snippet to format 4 int32 into string  with comma as separator
i320=-2139999999L;
i321=-2139999999L;
i322=-2139999999L;
i323=-2139999999L;
#ifdef _DM output_high(pin_b3); #endif
ptS = i32toa(i320,tS);
*(ptS++)=',';
ptS = i32toa(i321,ptS);
*(ptS++)=',';
ptS = i32toa(i322,ptS);
*(ptS++)=',';
ptS = i32toa(i323,ptS);                  //total 10ms
#ifdef _DM output_low(pin_b3); #endif
fprintf(debug,"%s\n",tS);
PostPosted: Fri Jan 02, 2009 3:14 am     Reply with quote
You might find a more efficient '%', with a search here. Though things may have changed.
CCS, 'waste' a lot of time in several places using %. Their implementation, performs a division, then takes the integer part of the result, and multiplies this, subtracting this result from the original to get the %. In many places, they perform this, and a division again, as well, to get the part needed for the next operation!.....
A long time ago, I found that in fact their division code, had the remainder already present in a temporary store, and the two divisions, and one multiplication used to get the values needed, could be replaced with just one division, if you accessed this. I posted a routine to do this. It was though a long time ago (probably on the old board), and I have no idea what the thread was called, but a search might find it. Made a massive difference to the performance...
