CAN and RS485 don't work in one file
t90
PostPosted: Wed Dec 31, 2008 6:03 am     Reply with quote
I have a problem with CAN bus and RS485. When CAN bus in single file it work well, RS485 work also. But when I implement those in same file they don't work. Please help me!
Here is my code.
#include <18f4680.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, stream=PC)
#define  RS485_RX_BUFFER_SIZE 64
#define  RS485_USE_EXT_INT    FALSE
int8 OUR_RS485_ID = 0;
#define RS485_ID OUR_RS485_ID
#include <rs485.c>
#include <stdlib.h>
#include "my_can.c"
int1 flag;
int flag1;
int flag2;
int16 count;
int cmp[4];
int8 msg[8];
int i;
void delay_seconds(int n) {
  for (;n!=0; n--)
  delay_ms( 1000 );
   cmp[0]=0;
   cmp[1]=1;
   cmp[2]=2;
   cmp[3]=3;
   set_tris_b(0x00);
   set_tris_c(0x00);
   flag=0;
   flag1=0;
   flag2=0;
   count=0;
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4); // rs485 ko chay
   enable_interrupts(int_timer0);
   my_can_init();
   my_can_set_id(111);
   rs485_init();
   while(1){
         if(rs485_get_message(msg, TRUE))
            /*printf("\n\r%d: ", msg[0]);
            for(i=0; i < msg[1]; ++i)
               putc(msg[i+2]);
            printf("\n\r");*/
            flag1=4;
         //restart_wdt();
         if ( can_kbhit() )   //if data is waiting in buffer...
            if(can_getd(rx_id, &in_data[0], rx_len, rxstat)) { //...then get data from buffer
               if(rx_len<=MY_CAN_BUFFER_SIZE){
                  if(rx_id==my_can_id){
                     if(memcmp(in_data,cmp,4)==0)
                        flag2=4;
                     //output_toggle(PIN_B4);
                     output_bit(PIN_B5,in_data[0]);
                     output_bit(PIN_B4,in_data[1]);
                  else{
                       printf("\r\n ID=%Lu Data not for me !\r\n",rx_id);
               else{
                  printf("\r\nFAIL on rx_len\r\n");
            else {
               printf("\r\nFAIL on GETD\r\n");
      //out put to check for receive data
     if(flag1==4){
          output_bit(PIN_D0,1);
          delay_seconds(3);
          output_bit(PIN_D0,0);
          flag1=0;
      }if(flag2==4){
          delay_seconds(1);
          flag2=0;
PostPosted: Wed Dec 31, 2008 12:09 pm     Reply with quote
You have enabled Timer0 interrupts, but you don't have an #int_timer0
interrupt service routine.
t90
PostPosted: Wed Dec 31, 2008 7:31 pm     Reply with quote
I use #int_timer0 to handle the data receiving from RS485. But it don't
work, so that I delete #int_timer0 but I forget to delete setup_timer0.
Now I delete setup_timer0 but it still don't work. Please help me
PostPosted: Wed Dec 31, 2008 7:52 pm     Reply with quote
Delete these two lines:
t90
PostPosted: Wed Dec 31, 2008 8:23 pm     Reply with quote
I delete it, but it don't work.
