Newbie problem about hyper terminal putc getc
PostPosted: Mon Dec 29, 2008 12:29 pm     Reply with quote
I would like to send and receive integer numbers via hyper terminal by using pic16f877a. But i couldnt do it. where am i wrong? could anyone help me please?
Here x[4] is a string and i should send integer numbers of each members of x[i] string via hyper terminal. And I should see the value of the y0 on the screen.
#include <16f877a.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000)
#use rs232(baud=300, xmit=PIN_C6, rcv=PIN_C7,parity=N,stop=1)
char x[4];
char y0;
int i;
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
for(i=0,i<=4,i++)
x[i]=getc();
 y0=(x[0]-6*x[1]+x[2]+4*x[3]-5*x[4]);
 putc(y0);
 getch()
PostPosted: Mon Dec 29, 2008 12:50 pm     Reply with quote
You don't receive integer numbers in your example, you receive (and send) character codes. That's obviously not the right way to achieve number calculation.
Why do you setup the SPI interface, b.t.w.?
SherpaDoug
PostPosted: Mon Dec 29, 2008 12:57 pm     Reply with quote
Your program may be working in binary, but Hyperterm doesn't display the binary of the serial port. It interprets the bits as ASCII characters.
Try printing known numbers to your PC with printf() and with putc() and examine the difference.
PostPosted: Mon Dec 29, 2008 1:05 pm     Reply with quote
This block of code is created by the "Wizard" feature of the CCS IDE.
The Wizard puts in code to disable modules, even though they are already
disabled upon power-on reset.
PostPosted: Mon Dec 29, 2008 2:20 pm     Reply with quote
This block of code is created by the "Wizard" feature of the CCS IDE. The Wizard puts in code to disable modules, even though they are already disabled upon power-on reset.
I see. Unfortunately it's not disabling SPI but enabling it, creating serious problems with some PICs, when it overwrites UART pin settings, see this today's thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=37196
One more erroneous PCW V4.0 feature needing correction.
PostPosted: Mon Dec 29, 2008 2:31 pm     Reply with quote
So what should I do now? what would you do if you were me?
PostPosted: Mon Dec 29, 2008 3:18 pm     Reply with quote
If you want to receive numbers rather than digits, you have to define an input formatting first. A possible format would be to use <CR> as a delimiter, you can use gets() function to retrieve strings terminated with <CR> and atoi() to convert them to numbers, each. printf() can be used to show the result.
Markdem
PostPosted: Tue Dec 30, 2008 7:37 am     Reply with quote
First, I would try to get the code to compile, you are missing a while loop and the last closing bracket.
When I work on something new, and I bet most other people do to, I try to work in small steps. Why don't you try to just receive one byte, and echo it back to see what the PIC has received. As mentioned before, it will not be what you type into the PC.
Next, see the CCS manual and check out what ATOI() does.
Also, I would check the #USE RS232 statement. It is a good idea to put errors at the end of it eg.
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,errors)
See how you go.
Mark
