Digital power switch
championx
PostPosted: Mon Dec 29, 2008 12:24 am     Reply with quote
Hi! i am working on a 18f252 battery powered project... i use a standard power switch to turn on and off the circuit... but now i want to turn on and off the circuit by pressing a pushbutton... like a cellphone...
I tried a N CHANNEL MOSFET, but when i drive the gate low, the circuit turn off.. but not entirely...
any ideas???
i cant use the SLEEP function because the consumption on sleep mode is too high (300uA)
thanks!
PostPosted: Mon Dec 29, 2008 1:37 am     Reply with quote
With appropriate configuration, the sleep mode current consumption can be as low as a few uA with most PIC devices. This requires, however, to disable oscillators and any additional internal load, e.g. brown-out detection. Also the port pins must be configured in a way that avoids additional current draw, particularly by floating inputs or loaded outputs and pull-up resistors.
An external switch transistor can further reduce the current, if required. It's difficult to understand, why your circuit doesn't operate as intended, without knowing the schematics.
championx
PostPosted: Mon Dec 29, 2008 7:12 am     Reply with quote
I cant use SLEEP mode because the circuit have a few components that cant be turned off, like LCD, some zener diodes, etc.
I dont have the schematics. But i have succesfully use the sleep function on other proyects, but in this one, i have to make a DIGITAL SWITCH, any ideas?
PostPosted: Mon Dec 29, 2008 7:33 am     Reply with quote
You didn't tell, that the power consumption is from external parts. My usual solution is to use a switch for the external parts supply and Sleep mode for the processor. Either a NMOS/NPN switch in negative supply or PMOS/PNP switch in positive supply can do. Obviously you have to set the port pins connecting the switched peripherals to an appropriate state.
championx
PostPosted: Mon Dec 29, 2008 7:36 am     Reply with quote
yes, i know, the problem is that the circuit is already made, so i cant modify the hardware, i just can add a digital switch to it.
PostPosted: Mon Dec 29, 2008 8:16 am     Reply with quote
As mentioned before by FvM, it is difficult to help with your problem without knowing the schematics. Can you post a picture/drawing? Or describe in words how you connected the mosfet?
Using Google I found many 'power off' schematics, for example http://www.edn.com/archives/1996/120596/25di_03.htm
Does your setup look similar to this one?
championx
PostPosted: Mon Dec 29, 2008 9:30 am     Reply with quote
hi ckielstra! i can give you a description:
Is a 18F252 at 20mhz
-I2C memory
-I2C RTCC
-LCD 16x2
-ONE ADC
-LDO 5v regulator.
-5 pushbuttons
The switch is between the pic and the 5v regulator. When turned OFF, it cut off the power from the circuit, except the RTCC.
I only replaced the switch for a 2n7000 Nchannel mosfet. But didnt worked...
I will try this circuit, do you know a P channel mosfet like the 2N7000 (to92)???.
thanks!
SherpaDoug
PostPosted: Mon Dec 29, 2008 9:38 am     Reply with quote
If you switch off power to the VCC pin of a PIC but leave +5V going to any port pin (with a few odd exceptions) the protection diode of the port pin will forward conduct to the VCC bus of the chip, thus powering the PIC at a reduced voltage.
Maybe this is what you mean by the circuit turning off but not entirely.
championx
PostPosted: Mon Dec 29, 2008 9:42 am     Reply with quote
Hi SherpaDoug, no, i mean that the mosfet doesnt entirely cut off the power. I dont have any pin connected when vcc is off. The only thing connected is the RTCC bat pin.
PostPosted: Mon Dec 29, 2008 10:03 am     Reply with quote
An NMOS switch connected to VCC would need a gate voltage above VCC for suitable operation. I already made a comment about the useful options with NMOS and PMOS transistors, I've nothing to add to.
Another point, I don't fully understand. You're talking about a voltage regulator. What is it's supply current? As far as I know, even said micropower regulators have about 100 uA supply current at no load. This doesn't sound well-thought. So, if you need voltage regulator and a supply switch, a regulator with disable as a LP2985 seems more suitable.
championx
PostPosted: Mon Dec 29, 2008 11:13 am     Reply with quote
The regulator that i use have a very low current, about 5uA...
