please save me from PCD
drdelphi
PostPosted: Tue Oct 07, 2008 5:03 am     Reply with quote
hey
pic24FJ32GA002, PCWHD 4.080
const int ID = 20015;
char a, b;
a = ID >> 8; // a is 78 - ok
b = ID; // b is 47 - ok ... 78 * 256 + 47 = 20015
a ^= 170; // a is 228 - perfect
b ^= 85; // b is 177 ??? should be 122
ok ... let's switch the last two lines ...
b ^= 85; // b is 27 ??? should be 122
What am I missing here ?
drdelphi
PostPosted: Tue Oct 07, 2008 5:12 am     Reply with quote
one more for the road ...
  boolean v, g;
  g = false;
  v = true;
  printf("G=%u V=%u\n\r", g, v);
Guess what the output is ?
"G = 0 V = 0"
Shocked
MicroManiac
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Oct 07, 2008 5:14 am     Reply with quote
one small question because i didn't understand what you are doing,
if you want to add why don't you use the a+=170??
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein
PostPosted: Tue Oct 07, 2008 5:16 am     Reply with quote
^ does not stand for addition. it is XOR eXclusive Or
any other suggestions ?
drdelphi
PostPosted: Tue Oct 07, 2008 5:27 am     Reply with quote
I found one way to solve the first problem:
char a, c, b;
a = ID >> 8;
b = ID;
a ^= 170;
b ^= 85; // b is 122 as expected
so just adding a dummy 'c' variable between a and b solved the problem.
before
.................... a ^= 170;
0AD0: MOV 2414,W0
0AD2: XOR.B #AA,W0L
0AD4: PUSH 2414
0AD6: MOV.B W0L,[W15-#2]
0AD8: POP 2414
.................... b ^= 85;
0ADA: MOV 2414,W0
0ADC: XOR.B #55,W0L
0ADE: PUSH 2414
0AE0: MOV.B W0L,[W15-#1]
0AE2: POP 2414
now
0AC8: MOV 2414,W0
0ACA: XOR.B #AA,W0L
0ACC: PUSH 2414
0ACE: MOV.B W0L,[W15-#2]
0AD0: POP 2414
0AD2: MOV 2416,W0
0AD4: XOR.B #55,W0L
0AD6: PUSH 2416
0AD8: MOV.B W0L,[W15-#2]
0ADA: POP 2416
PostPosted: Tue Oct 07, 2008 10:07 am     Reply with quote
Yes, PCD, is still showing strong signs of 'beta' status...
There have been several other oddities reported here in the recent weeks.
As a completely 'silly' test, what happens if you use explicit, rather than implicit allocation of the source. So:
a = a ^ 170;
b = b ^ 85;
You need to report the fault ASAP, anyway, but it'd be interesting if this changed things.
drdelphi
PostPosted: Tue Oct 07, 2008 10:11 am     Reply with quote
It doesn't change anything.
this problem appears only with char type. if I declare the variables of type int which in this version is signed int16, it works.
FvM
PostPosted: Tue Oct 07, 2008 11:13 am     Reply with quote
Welcome to the PCD beta tester community!
I've found, that int8 operations generally have a higher risk of revealing PCD bugs. This shouldn't be accepted, but apart from claiming correct operation with int8, using int16 produces more effective code in most cases. Thus, if your RAM isn't running short with your application, you should consider to use int16 for simple work registers and similar purposes.
Although I recently found 3 different PCD bugs at one day, I can say, that I already finished a complex application, involving e. g. a MODBUS slave and EEPROM emulation with PIC24F. Many things have been working from the start. Thus I won't shout "Save me from ...". There is however a lot of work left for CCS, and I think, they know about.
Best regards,
Frank
FvM
PostPosted: Sun Dec 28, 2008 11:27 am     Reply with quote
The bug discussed above has been finally fixed in V4.084, also some wrong SFR addresses related to IO-ports. Unfortunately, a lot of other bugs apparently hasn't been touched yet. PersonaIly, I have still 6 pending bug reports of october and november, and I expect there are some more.
Best regards and a Happy New Year!
Frank
dolleman
PostPosted: Sun Dec 28, 2008 4:03 pm     Reply with quote
the easyist way in pcd is to break your code into smaller lines. to find where it breaks, it may take more lines of code but then it works. just because it's leagal code does not mean ccs has it all working.
FvM
PostPosted: Sun Dec 28, 2008 4:28 pm     Reply with quote
This is, what I basically did. To understand, what this easyist way really means, I suggest to take the RFC1321 MD5 implementation and break the code into smaller lines until it operates correctly. A mathematician would say: a finite solution exists.
