Missing address for a goto in the C/ASM Listing
Herbert
PostPosted: Fri Dec 26, 2008 9:07 pm     Reply with quote
Does anybody have any thoughts on the following observations, please. Compiler is PCWH V4.079, developing for a 18F2620.
After a successful compile the C/ASM listing shows the following (with a lot of gumpf taken out)
1034:  GOTO   1058
....................         case AAA       : Switch_to_AA();
1038:  CALL   0264
....................                  break;
103C:  MOVLB  3
103E:  BRA    1054
....................         case BBB    : Switch_to_BB();
1040:  BRA    0FE6
1042:  MOVLB  3
1044:  BRA    1054
....................         case CC      : Switch_to_CCC();
1046:  BRA    0FFC
1048:  MOVLB  3
104A:  BRA    1054
....................         case External_Port : Switch_to_External();
104C:  BRA    1012
104E:  MOVLB  3
1050:  BRA    1054
1052:  MOVLB  3
1054:  MOVLB  0
1056:  RETLW  00
....................    int8 DDD[6];
....................       If ( GGG < HHH)
1084:  MOVF   53,W
1086:  SUBLW  09
1088:  BNC   10D2
The GoTo refers to an address 1058, which does not exist in the listing. The addresses jump from 1056 to 1084, with nothing in between. A search of the C/ASM listing only shows a reference to it in the goto.
Also notice that addresses in the rest of the listing are not always sequential. Blocks of addresses can be in totally different positions, is this normal?
Trying to chase a problem where the position of a bit of code determines how other bits of code execute. I expect its a pointer problem, but seeing a listing with missing addresses is a bit of a concern.
PostPosted: Fri Dec 26, 2008 11:30 pm     Reply with quote
To see all the CCS library code, comment out the #nolist statement near
the start of the 18F2620.h file. Example:
//////// Standard Header file for the PIC18F2620 device ///
#device PIC18F2620
// #nolist
Then re-compile and look at the .LST file again.
andrewg
Re: Missing address for a goto in the C/ASM Listing
PostPosted: Sat Dec 27, 2008 12:02 am     Reply with quote
Yes. The compiler will reorder code to achieve a more optimal arrangement.
Andrew
Herbert
PostPosted: Sun Dec 28, 2008 7:09 pm     Reply with quote
Thanks very much PCM and Andrewg. Feel better now! It starts to make more sense.
