leejok2003 Guest
Need help with ccstcpip.h... |
Posted: Thu Dec 25, 2008 9:15 am |
Hi, recently i am do some study regarding CCS tcpip. When i look into the codes, i get stucked with these:
*0xF92=*0xF92 & 0xFC; //a0 and a1 output
*0xF93=*0xF93 & 0xCF; //b4 and b5 output
What does it means with 0xF92? And where can i find them? Thanks...[/code] |
asmallri
Joined: 12 Aug 2004 Posts: 1635 Location: Perth, Australia
Re: Need help with ccstcpip.h... |
Posted: Thu Dec 25, 2008 9:42 am |
leejok2003 wrote: | Hi, recently i am do some study regarding CCS tcpip. When i look into the codes, i get stucked with these:
0xF92 is the address of TRISA
0xF9B is the address of TRISB
The code is setting up a0, a1, b4 and b5 as outputs. _________________ Regards, Andrew
Posted: Thu Dec 25, 2008 9:48 am |
It's an alternative syntax for accessing PIC18 SFRs, curiously never mentioned in a CCS C manual, as far as I'm aware.
A more usual syntax would be
#byte TRISA = 0xf92
#byte TRISB = 0xf93
TRISA &= 0xFC;
TRISB &= 0xFC; |
leejok2003
Posted: Thu Dec 25, 2008 9:57 am |
Oh...now i see...thanks guys |
