fvnktion
RDA interrupt non-responsive |
Posted: Tue Dec 23, 2008 6:12 pm |
I am in the middle trying to implement a serial interrupt using the #int_rda. It works fine in a test program, but when trying to port it into a project it does not respond. There seems to be some conflict with existing usage in the project.
I am using rs232 to output data, and have a I2C bus, which is active and am running and LCD. The only one that i can see being a problem at all would be the I2C as it uses some of the serial registers.
Are there any other problems that I may be running into? Is it possible to use I2C and the RDA interrupt simulaneously?
Here are the fuses that i currently have enabled:
#include <18F4520.h>//CCS 4520 header file for registers
#define OSC_FREQ 4000000
//Fuses
#fuses INTRC//HS //INTRC//HS//INTRC
#fuses NOPROTECT,MCLR,NOBROWNOUT,BORV45,NOWDT,NOPUT,NOSTVREN,NODEBUG
#fuses NOLVP,NOWRT,NOCPB,NOWRTB,NOWRTC,NOCPD,NOWRTD,NOEBTR,NOEBTRB
#fuses NOXINST //extended cpu
#use delay(clock=OSC_FREQ)
//RS232 Setup
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,bits = 8)
Compiler:4.083
Thanks for the input. |
Posted: Tue Dec 23, 2008 6:55 pm |
Comment sections of code until it starts working. For example, if you
call a routine to read the temperature from an i2c chip, then comment
out the "guts" of that routine. Then temporarily insert code in that
routine to return a hard-coded value for the temperature. For example,
always return 70 degrees (Fahrenheit). Also, comment out the
#use i2c () statement and any code that initializes the i2c pins. If the
you suspect that the i2c is causing the problem, this trouble-shooting
will help you to see if it's true. |
fvnktion
Posted: Wed Dec 24, 2008 11:00 am |
Thanks for the great advice PCM. Just to update the post in case anyone else is interested.
I did what you recommended and did end up getting the the INT_RDA to by basically eliminating all use of the I2C. I thought that I would try and older version compiler to see if there was any difference in outcome. I loaded 4.057 and all of the code with all functionality enabled worked fine. I reloaded 4.083 and somehow someway all of the code was working fine.
Some crazy black magic going on there somewhere. Possibly a corrupted file or some other reinstall fixing solution.
Anyway, thanks for the help.
Cheers |
