I use 16f877a which is master and another 16f877a is slave.
master:
pin A5 (select)
//master
#define SS_LOW (output_low(pin_A5)) //pin RA5 conected to nSS in 16F877A
#define SS_HIGH (output_high(pin_A5))
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END); // TODO: USER CODE!!
int rs;
SS_LOW;
while (true)
spi_write(0x55);
delay_ms(1);
rs=spi_read();
delay_ms(1);
if(rs==0x33)
portd=0xff;delay_ms(500);
portd=0;
//slave
int kq;
setup_spi(SPI_SLAVE | SPI_H_TO_L);
kq = spi_read();
delay_ms(1);
portd=kq;
spi_write(0);
but when i test with proteus, nothing perform on slave's Portd
please show me what problem i face
Thanks guys
Posted: Fri Dec 19, 2008 4:55 pm
The SPI master needs to output an SCLK signal when it reads a byte
from the slave. In CCS, this is done by giving the spi_read() function
a parameter. Change your master code to this:
rs=spi_read(0);
Now you will get the SCLK in the read operation, and you can continue
working on your design.
